Question about Remington Electric Chain Saw
I have a LD4018AW el-9 Remington chain saw I weant to change the chainsaw blade. It has a orange plastic cover over the sprocket. Need a step by step on what to take apart to swich blades
Cant get to sprocket to switch blades . Has a orange safety cover. I have the book, does not show how to remove saw blade.
4 Suggested Answers
  • 42 Answers
SOURCE: can you send me a manual for the 18" Remington electric chain saw
Here is the web site where you can download the manual at:
http://www.desatech.com/manuals.cgi?oldpro=Chainsaws&products=Chainsaws&Manual=LD4018AW&Model=&Type=Show+All&x=105&y=13
Posted on Mar 07, 2009
steve_lima
  • 181 Answers
SOURCE: Remove range cover on remington chainsaw Model LD4018Aw
this web site has partsbreak downs.................http://www.masterparts.net/ hope this hepls,let me know
Posted on Jun 02, 2009
  • 4088 Answers
SOURCE: I have a remington 18
Look up Oregon saw on the web for bars and chains to fit nearly every saw made. Good luck!
Posted on Dec 22, 2010
14SB REMMINGTON HOW TO REPLACE THE CHAIN
Remove the cover, loosen the bolts to allow the bar to slide toward the sprocket. Lift chain off the sprocket and pull out from the notch in the bar. Be sure to turn the chain the same direction, otherwise you will be cutting with the back side of the blades. Slide the new chain blade onto the sprocket then fit into the bar. Once that is accomplished pull the bar firmly outward watching to see that the blade stays inside the slot of the bar. While keeping pressure on the chain and bar, tighten the retaining bolts and replace cover
Sep 28, 2014 | Remington Electric Chain Saw
I NEED A REPLACEMENT CHAIN FOR A REMINGTON EL-2 CHAINSAW THANKS FOR ANY HELP.
Take your chainsaw to a saw shop that repairs chainsaws. They should be able to make one for you or look one up and order it for you. I have found shops in the yellow pages looking under saws.
Jul 26, 2012 | Remington Electric Chain Saw
Change blade
all chain saws have a sprocket that the chain runs on this sprocket is what make the chain rotate on the bar. the bar is the long part that sticks out in front of the motor. you must remove the side cover of the saw to access the sprocket region of the saw. be sure the saw is unplugged and then remove side cover the bar is usually held in place by a couple of bolts. on gas saws these two bolts also hold the side cover in place and must be removed to replace the bar and chain. once you have removed the side cover look for bolts holding the bar in place. if you only want to change the chain then you may be able to only loosen the bolts or screws holding the bar in place.there should be a screw to adjust the bar forwards and backwards. this screw put tension on the chain so when you put a new chain on turning the screw will proberly tension the chain /do not overtighten the chain.
also be sure you put the new chain and blade on the same as the old one that comes off trying to cut with a chain that is on backward does not work. last note if you are replacing the blade because the old one is dull take the saw to a saw shop they can sharpen the exsisting chain and save you money.
Jan 24, 2011 | Remington Electric Chain Saw
I have a remington 18 inch chainsaw model #EL-9 LD4018AW and need a chain who can I order one from?
Dec 22, 2010 | Remington 16" Electric Chain Saw
Where can I order parts for my 16 inch electric Remington saw.
Usually any where that repairs lawn mowers, snowblowers, and chain saws or places that sell them like Sears.
May 13, 2010 | Remington 16" Electric Chain Saw
How do I tighten the chain on my Remington 14 in. 2 hp electric chain saw? Have used tightening screw, does do anything. Loosened the blade bolts trying to move the blade out slightly. Doesn't work...
Mitch if you attempted what is in the manual, and it is not working we would have to see and touch the saw to determine what has failed. If you loosened the bar bolts before trying the adjuster and it did not work, I suggest a trip to a local saw shop.
Chain adjustment pages 1, 8 and 9.
This is from a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Remington Electric Chain Saw
I need to remove the orange cover
to me it sounds like the adjuster screw is bent stopping the cover from comming off.bad news is that cover is no longer avalible.the cost on that cover is $5.95 if you can find one.the cover only came as an assembly.you can try this place and see if they have any more.....http://www.masterparts.net/
Jun 01, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
