Question about Taylor & Digital Scale Lithium Scale
Why does my taylor 7405 scale displays 0.0 and wont weigh?
5 Suggested Answers
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
F1xer
  • 415 Answers
SOURCE: Taylor Model 7314 Lithium Scale: Scale
Try stepping off the scale when you get an error message wait 5-10 secs then step back on, remember to stand still when the scale is giving a reading
Posted on Aug 15, 2010
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Tells different wieght each time
    Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
    If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
    Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
    Mar 02, 2011 | Taylor Body Fat Analyzer & Scale, Model...
    Gives me diffrent weights even though I am weighing myself within seconds of time, and in the same spot on the floor.
    I've found I have to weigh myself, step off, weigh myself with something in my something heavy in my hands, then weigh myself again. The 3rd weight you get will be your correct weight. If you needed the manual, I have uploaded in into photobucket...although it doesn't really address this issue.
    http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
    Amy
    Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
    Taylor 7532S, battery replaced, error message 0-Ld
    Try to reset the unit. Use the following steps
    - Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
    - Remove the battery from the compartment. Close the battery compartment door.
    - Sit the scale right side up on a hard surface floor.
    - Step on the scale and stand still on it for five to ten seconds. Step off the scale.
    - Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
    - Place the scale right side up on the hard surface floor.
    - Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
    - Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
    Hope this solution has been helpful?
    Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
    Mar 16, 2009 | Taylor 7532 Ultra Thin Glass Digital Scale
    Taylor 7530 scale wont turn on,i have new batteries
    Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
    Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
    Taylor & Digital Scale Lithium Scale  Logo
    55 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
