Question about Pioneer PDP-507XD 50 in. Plasma Television
USB port on Pioneer PDP-507XD 50 - Pioneer PDP-507XD 50 in. Plasma Television
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
Posted on Jan 10, 2011
walesarumi
  • 6993 Answers
SOURCE: We cannot switch on our
First, remove the TV plug from the wall, fix it back in and try again. If that doesn't solve the problem, then it means your TV is having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 01, 2011
DrewPalmer04
  • 325 Answers
SOURCE: We have had problems switching
I've been running across a lot of plasma tvs where the power supplies are not bad, but the X & Y-sustain boards are faulty. My advice is to change those boards out as they are responcible for lighting the plasma gasses in the tv. You can attempt to replace one at a time (cost reasons), but it is recommended to changed both at once.
Hope this helps, please rate. :)
Posted on Apr 11, 2011
AJIN G
  • 6694 Answers
SOURCE: Problem with Pioneer PDP-5080HD 50
hi,
There is some over heating problem in you television. there will be two fans inside you television. if any of the fan get faulty then that section of you TV will get over heated and will shut off by itself preventing from further damages. Check the two fans. For that you have to open your TV.
ok
Posted on Jun 07, 2011
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
Our tv is about 10 years old. All of the sudden, the visual just shuts off- the sound is on, but the visual goes black- A few times, we've been able to reboot the whole system and it would come back up,...
On a 10 year old Pioneer, this may be an expensive repair. There were several boards that could cause the same symptoms. If it is not a power supply problem you may be chasing your tail. If the capacitors in the power supply caused this, you should be looking at $125-250 us dollars. If they say it's the main drive boards.... run away. Buy a new set. Just my best guess from experience.
Good luck, Russmann.
May 03, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
We have had problems switching on our Pioneer PDP-507XD plasma tv. The standby light just flashes. We were advised to change the power supply unit. We hav4e done this and it has not solved the problem ...
Apr 11, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
Sound is not working. everything is plugged in right. got the tv from my father-in-law who always had it hooked up to a receiver box. now we have it and dont have a receiver box and are unable to get any...
it sounds like the internal speakers are just off. you should be able to navigate the menu and find where to turn the speakers back on. i have my tv set up with a surround sound system and turned the internal tv speakers off. should be in the sound settings or with a picturre of a speaker.
Dec 24, 2010 | Pioneer PDP-507XD 50 in. Plasma Television
None of the HDMI inputs work
Tries the S-Video cable.Use that connections?
Check the HDMI input on the menu must be on or auto.
Aug 13, 2009 | Pioneer PDP-507XD 50 in. Plasma Television
Pioneer PDP-507XD 50 in. Plasma Television Logo
64 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
