Question about GE Heating & Cooling
Technical support hi, i'm a service technician. seeking for phone technical support on a pagckage air conditioner unit. model az75e12dacm1 can you help me out.
  • 334 Answers
This should help.
http://www.geappliances.com/service_and_support/contact/
1-800-626-2005
Also remember we can provide troubleshooting through chat here if you like.
Posted on Jan 20, 2009
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
I have a Carrier heating unit in my attic ,
zone controller might be stuck seek help from service co.
Mar 25, 2015 | Carrier Heating & Cooling
My Aircon indoor unit will not run continually on cooling. It runs for short bursts then stops.
One thing that I am not seeing in your description is that the coil sensor has been replaced. I find it strange that a phone tech could diagnose this, send out a technician and not replace this component. Was the service tech an authorized LG repairman? That is where I would start. I would call LG and ask them for a certified technician supported by LG in your area. I feel you will have better luck with that approach.
Jan 31, 2015 | LG Heating & Cooling
Service manual or parts manual for a Dayton Model 3ve59a Propane Gas Heater . 375,000 btu unit. Where can I find this document
Dayton is made for Grainger Supply. You can contact their Technical Service Dept at 888-361-8649.
They can provide a Service & Parts Manual for you.
Mar 08, 2011 | Heating & Cooling
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Goldstar model number wg1205r AIR CONDITIONER, NOT COOLING
thermal relay is not functioning , u need service technician
May 15, 2009 | Heating & Cooling
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
AC not working
Hi, If you are renting your home, contact the owner or manager. If this is a window unit it may have a reset button at the plug. You also need to check the main breakers in the breaker panel. If its a split unit, I think you should contact a licensed air-conditioning technician to check it out. Find the REPAIR SERVICE tab on here and find one in your area or check the YELLOW PAGES in your phone book under HEATING AND AIR-CONDITIONING. You might want to talk with a neighbor to find a good air-conditioning technician. Without further information, I cant think of anything else. Hope I have helped you. kstfas
Sep 11, 2007 | Heating & Cooling
Purchased a sf-610 today floor model, no manual
Hi, I would start with the store where you bought it. Sounds like you got an incomplete unit. If not, they may be able to get a manual out of another unit. Don't see any manuals on line but 1-800-330-0388 is their phone number for customer service. Explain to them the situation and ask for technical services. They should be able to send you a manual and answer any questions you have on the unit. Write them all down before you call them. Hope I have helped. kstfas
Aug 18, 2007 | Sunpentown SF-610 Portable Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
