Question about Dryers
Heller ruby ceiling fan with light and remote dosent work
SOURCE: Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Posted on May 27, 2008
jmgldsmth
  • 2005 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
SOURCE: Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Posted on Jul 03, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
43 people viewed this question
Top Dryers Experts
