Question about Toshiba DVR620 DVD Recorder/VCR
I cannot get the Toshiba dvr620 to dub properly from a homemade vhs tape to a formatted dvd+rw. Also, there is no picture when I hit the dub switch.
What is going-on? I went through the manual procedures three times and it still did not work. The vhs tape did not play and the dvd recorded material but was not visible when I played the dvd. I know it recorded material because it needed to be formatted again.
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
hbsurfdawg
  • 95 Answers
SOURCE: toshiba d-vr600 record without viewing the whole tape
Unless both units has stated high speed transfer capabilities I think you have to do them one at a time and watch the entire video.
There are some units that are one unit for vhs to dvd. Panasonic is known to have some units but you are going to probably have to hunt for one. It will clearly state that it transferred compressed or highspeed.
Posted on Mar 02, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
Posted on May 30, 2009
SOURCE: toshiba D VR660KU DVD VCR combo
The unit will only allow 2 hour recording on the DVD+R format. The DVD-R format is adjustable for longer recording time, just understand that the longer recording times = the lower the quality of the recording.
Posted on Jul 07, 2009
Using the toshiba DVR620 and dubbing vhs to dvd+rw
I hook up an external monitor with a speaker. An old portable TV will do it, preferably one with a line in and line out. Connect your VHS machine to line in on the DVR620. Connect your monitor to line out and audio out. Monitor as you play.
Jun 23, 2014 | Toshiba DVR620 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I am going out of my mind trying to dub VHS to DVD on my new Toshiba DVR620. Please help!
I have a Toshiba HDD&DVD vcr RD-XV48DTKB will not accept disc or play any disc have tried several makes even new ones it just loads then says error cannot play eject will not play or record HELP
Jan 22, 2011 | Toshiba DVR620 DVD Recorder/VCR
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Just got this Toshiba DVR620KU and need to record from home movie VHS to DVD. Have DVD-R, I have set the time, have it on the program VHS to DVD, I start the VHS, put it on pause. Go DVD, select rec...
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
Apr 22, 2010 | Toshiba DVR620 DVD Recorder/VCR
How do you dub my VHS tapes to DVD with the Toshiba DVR620 Recorder
plug the composite cables from the vcr output to the dvd recorder in
yellow, red, and white
use output from the dvd recorder to a tv so you can see what is happening.
Jan 14, 2010 | GoVideo DVD Recorder/VCR with YesDVD
Panasonic DMR-E75V Dubbing Problem
you will need to finalise the disc in your DVD recorder before it will play on any other equipment
Nov 18, 2009 | Panasonic DMR-E75V DVD Player/VCR
Recording dvd from vhs
you may not need a remote to dub a vhs tape to dvd.
look on the front of the recorder. see if there is a arrow showing dubbing vhs to dvd/ dvd to vhs. since you do not have the manual, you'll probably have to play around with it a while to figure it out. you will also need to know which format the dvd will record on. [dvd-r,dvd-rw,dvd+r,dvd+rw or ram] you can look up your recorder brand & model # online, then search for a manual you can download.
good luck.
wg
Feb 13, 2008 | LG RC797T
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
Toshiba DVR620 DVD Recorder/VCR Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
