Question about Kenmore Microwave Ovens
My Kenmore Microwave, Model 401.80093, shuts down as if there is no power, then after 15 to 30 seconds the panel lights back up and everything needs reset. The outlet and circuit breakers are not caus
Changing the power level doesn't seem to make any difference.
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air Microwave M169B 11 years old.
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 21, 2008
SOURCE: Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Posted on May 29, 2008
  • 4 Answers
SOURCE: dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
Posted on May 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
Posted on May 28, 2009
  • 10865 Answers
SOURCE: kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Posted on May 29, 2009
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 27, 2016 | Microwave Ovens
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Whirlpool RM988PYVW microwave oven
Wonder what that belt was? This model doesn't seem to use a blet of any kind. This may be a problem with the control panel assembly, which we repair nationwide for $39.95. Full information on our service is available at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Please feel free to follow up here or privately if you have other questions.
Aug 12, 2007 | Whirlpool RMC275PD Microwave Oven
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
