Copying on my Lexmark 6500 four function fax, copier, scanner, pr
It takes about 3-4 minutes to make a copy. The other 3 functions seem to work fine, but this seems too long. Am I doing something wrong?
Thank you,
King Ward
  • 92 Answers
Turn your copier and all attachments off wait ten minutes reboot should b ok
Posted on Aug 29, 2009
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Remove copying codes
F-5 service code 42 F5-42-0 set 42 to"0" no accounting,51-0 no copy account,52-0 no FAX account
To enter service mode,Function,copy, "3" simtameously default password 00000000 if changed willrequire a service technican who last service machine
Mar 30, 2010 | Panasonic Workio DP-1820E Copier
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Copying function
how much time it is taking to print a self-test page
Jun 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Lexmark X5150 All In One Printer
if ur getting black pages whn copying it shows that the scanner is defective. call lexmark tech support 800 332 4120 & have them give u a 20% discount to buy a new printer
Jun 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error: 2200
Scanner stall....try rebrickin the power supply and also check for the scanner lock and unlock it if its locked..also clear NVRAM
Apr 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark Printer
If the scanner is clicking than it is a scanner issue. Make sure there is not a lock button on the machine. They sometimes have these for when the printer is being moved. As for the faxing software it would seem that that part didn't not get installed so if you can update it.
Apr 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3 in 1
Too lengthy to resolve here, but goto lexmark.com to get "Fax cofiguration" info, I believe a phone line must be attached to printer in order to function as a "fax".
Dec 07, 2007 | Lexmark X4270 All-In-One InkJet Printer
55 people viewed this question
jasbo
jasbo
