Question about GE WSXH208A Front Load Washer
LOCK AND LOAD ISSUE
The washer machine is a front loader kenmoore high effeciency. First, the machine stopped and the lock button would not go off. Then,the light button went off and the machine opened. Also, the machine is now making a funny noise.
  • 164 Answers
Can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Posted on Jun 28, 2007
SOURCE:
The child lock on my LG front loader washer is now at about 5 minutes each load. How can I SUCCESSFULLY turn the thing off???
i think your issue is either the door lock itself or the control panel. i would start by unplugging the unit(or tripping the circuit breaker), then hold in the power button for about 10 secs--this resets many LG washer's electronics. then plug back in an see if that helps. i do not think your issue is the child lock feature, but rather the safety door lock feature. good luck.
Sep 17, 2016 | LG Washing Machines
How do I remove the locking function on my washer when already begun cycle so I can add an extra item I forgot put in without having start again. Is it possible?
On later model front loaders they have a Stop & Add button so when engaged you can add more to the wash load. Unfortunately earlier washers don't have it so once the cycle starts that's basically it. That's the reason some people prefer top end loaders as it not a issue
May 28, 2016 | Washing Machines
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Controls locked on front loader washer. please help
Press far right button ('with a lock picture) for 3 seconds, the lock will come off.
Sep 15, 2008 | Whirlpool GHW9150 Front Load Washer
Kenmoore wont spin front end loader
won't spin on the spin cycle it just has a grinding sound
Sep 10, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't start
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
