Question about Stanton T.60 Turntable
The 45rpm button doesn't work
The 33RPM button works fine but when I try to select the 45 it doesn't change
2 Suggested Answers
fire sine
  • 382 Answers
SOURCE: the 45rpm speed select button will not work
the 45 button is known as a push button switch. If the switch is affect, replacing should remedy, but it could be possible that the voltage variation on the motor is affected.
keep me posted.
Posted on Oct 28, 2007
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Technics 1200 mk2
Sounds like a short on the pcb, one of the IC's could have gone bad, or the 33/45 have shorted out. Unless you have the proper tools i can only direct you to who you could send it to or order the part(s) from. If youre good at soldering and can work in square inch spaces, go for..
http://www.djproaudio.com/cgi-bin/Help/pdesk.cgi?do=get_download&id=2&filename=MK2_cabinet.jpg
http://djproaudio.com/Store/advanced_search_result.php?keywords=Technics
http://djproaudio.com/Home/
Keep me posted.
Nov 18, 2007 | Technics SL-1200MK2 Turntable
The 45rpm speed select button will not work
keep me posted.
Sep 27, 2007 | Stanton ST-150 Turntable
Stanton T.60 Turntable Logo
41 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
