Question about Nintendo 3ds Handheld Game Console- Cosmo Black for DS
Access point's security settings are not supported by Nintendo DS
  • 7 Answers
SOURCE: i cant play online on mario kart on my ds
Try an another access point.
Posted on Jul 28, 2009
  • 110 Answers
SOURCE: re:-DS Lite.WiFi set-up. Asked for a Access Point.
The DS lite only supports WEP which would have a HEX key password, if you have a pass key or pass phrase then chances are you are using WPA or WPA2 which is not supported on the DS lite.
The WEP key is an older form of security and has been found to have some weaknesses but to be honest its still secure enough for a home wifi set-up.
Here is a link to an article explaining more about the differences between the two.
You can change your settings on the wireless router, but you will then have to adjust the settings on your Wii accordingly.
If you need any further help or advice please feel free to contact me via my profile page.
Regards,
SOD69
Posted on Feb 22, 2010
SOURCE: The access point's security settings are not
This can be fixed.
All you have to do is change the security settings in your router to WEP
The DS lite only supports WEP encryption, the DSi supports WEP and WPA (which is your current setting)
Just change in to WEP, and setup your DS + desktops/laptops again. Thats all!
Posted on Mar 05, 2011
technolust
  • 340 Answers
SOURCE: the access point's security settings are not
This means you've got a WPA/2 security connection on your router/access point, whereas the Nintendo DS only supports WEP or open encryption.
You can:
1) change your security from WPA to WEP on your router
2) Purchase a used nintendo wifi stick
3) Set up a second router or access point with WEP security specifically for your DS
Posted on May 16, 2011
  • 56 Answers
SOURCE: Access point security settings are not supported
Your network's security needs to be set to the WEP OR WPA security setting, as those are the only security settings that the 3DS is compatible with. Here are step by step instructions on how to change your security settings.
Posted on Aug 21, 2011
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
ยทError Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
I'm trying to get wi-fi on my nintendo ds but it keeps saying the access point's security settings are no supported by the nintendo ds.
You need to change the security settings on your router from WPA to WEP. WPA security is not supported by DS. Go to your router's wireless page and under security, change the settings.
Sep 19, 2011 | Nintendo DS Lite Console
Access point security settings are not supported by the nintendo ds3 system
Aug 21, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
I'm trying to connect to my wifi so I can play poke on soul silver online but when I search for an access point it tells me "the access point's security settings are not supported by the...
Nintendo WFC is only compatible with the WEP security setting, even when playing with a Nintendo DSi or Nintendo DSi XL. WPA and other security settings are not compatible.
solution: You will need to either change your security settings on your router to "WEP" (recommended), or disable all security.
for help with this: http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
Jul 25, 2011 | Nintendo DS Lite Console
Access points security settings are not supported by the nintendo ds
Attached is a manufacturer's link on how to get your problem solved.
http://www.nintendo.com/consumer/wfc/en_na/ds/wrInitialSetupHelp.jsp
I hope everything works out. Good Luck.
Jul 19, 2011 | Nintendo DS Lite Console
The access point's security settings are not supported by nintendo DS how can i solve this problem
The Original DS does not support WPA passwords, passwords you make up yourself to protect your network. The DS does support WEP passwords, a password randomly generated by the router.
You will need to switch your routers security to WEP or take off security entirely.
Jun 10, 2011 | Nintendo DS Console
The access point's security settings are not supported by the nintendo DS
You can:
May 16, 2011 | Nintendo DS Lite
My internet says the access point's security settings are not supported by the nintendo ds. for help visit support.nintendo.com. that is what it says.
Hi weigels,
I see you are getting an error security settigns not support by your Nintendo DS.
I beieve that you are trying to access a wireless connection using your Nintendo DS, the error that you are getting is actually an error saying that your Nintendo DS can detect the router but since your Router has a Network key you then get the error security settings not supported.
for a Nintendo DS it does not support Router settings that have a network security on it, you will have to disable the Routers Network security for you Nintendo DS to be able to access the wireless network of your Router, this will also prevent your Nintendo DS from getting the error security setting not supported.
Note: disabling your Network security will open your Routers signal to anyone who can detect the signal.
I hope this helps.
Have a nice day,
mvincentc
May 09, 2011 | Video Game Consoles & Games
Web setup
With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
  1. Tap Nintendo Wi-Fi Connection Settings
  2. Tap one of the Connection slots
  3. Tap "Search For An Access Point"
The Nintendo DS will then display the name of your wireless access point.
If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
NOTE: All information taken from http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp
Oct 09, 2010 | Nintendo DS Lite
Nintendo 3ds Handheld Game Console- Cosmo Black for DS Logo
15 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
