Question about Roper REX3614KW Electric Dryer
My dryer will not come on at all
Was working for a load took it out put another one in and it would not turn on . My husband thinks that it is the realy switch. i have only had this dryer for 2 years
  • Roper Master
  • 8,220 Answers
The duct fuse is probably blown. Mounted on the rear of the dryer on the blower housing. Make sure you get the lint out the dryer or you will be replacing this one a lot.My dryer will not come on at all - 5102b6e.jpg
Posted on Jan 19, 2009
Dryer worked for the 1st and 2nd load of clothes. Went to put 3rd load dryer wouldn't work. I checked to see if door was closed properly,and dryer turned on. I also had my husband to check our circuit...
it might be a partially blocked vent that causes the dryer to overheat over a period of use. trips the hi temp limit switch/thermostat. did it cool down and start working, or is this permanent.
Mar 27, 2015 | Maytag Dryers
My creda reverseair tumberledryer won';t work. my
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Dryer on sensor dry - gets stuck on 6 minutes and does not finish
We have been having this same problem. I had tried adjusting everything that I could think of when putting a load of laundry in and got the exact same results as you. I would select the sensor dry and it would count down just like normal until it got to 6 minutes and then it would just run forever at 6 minutes.
My husband and I searched online all this afternoon and came across what seemed way to simple to work. We removed the lint filter, unscrewed the filter housing right inside the door of the dryer, and got to the sensors. We took a damp cloth and wiped them off very well to remove any and all buildup. We wiped everything down very well to remove any built up lint and/or dirt and put everything back in place as was before. We then unplugged the dryer for about a minute and then plugged back in. We put a load of already dry clothes into the dryer and started as usual with the sensor dry. It started out at the usual 41 minutes then skipped down almost immediately to 6 minutes and then a few minutes later I heard the most beautiful sound I have heard in a long time. The Beeper signalling that the timer had counted down to the end and was finished. It had worked. Thankfully. Hope this helps you also.
Feb 10, 2009 | LG DLE2512W Electric Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Dryer has no heat
We have the same problem as posted above (dryer not heating up) only we have a Kenmore gas dryer Model 76702693. What should we do? Please help. Thanks.
Sep 11, 2008 | Kenmore 74832 Gas Dryer
No power to dryer
Does your Husband have a meter to check voltage? if not any good hardware store, Sears or Radioshack will sell you a meter for checking voltage at the outlet. I cant give him a lesson on electricity he has to feel comfortable with that.
I have witnessed many dryer installations where they blame the dryer and come to find out its the house wiring, oh bye the way here is my bill and you need to call an Electrician to replace this and he will bill you also. My service stops at the power cord! Make sure when your husband checks for loose wires he has the power off, if you are not sure of the correct breaker turn the main off. then he can check for all the loose wires and he wont fry himself.
I would also ask that you turn the breaker off and on several times to reset it, the dryer could still run but not heat if one side doesnt work.
Let me know if you have any further questions.
Jul 03, 2008 | GE DBSR453EBWW Electric Dryer
GE Profile Electric Dryer, Blower nt getting up to speed
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
More dryer problems!
if it goes off then restarts its depends on model if its even heat the even heat board in the top is bad and if it beeps few times it also needs a thermaster which is a black thing inside dryer with 2 wires going to it
Mar 04, 2008 | Kenmore 62802 Electric Dryer
On all the ones I've seen with this problem, they've needed a new blower motor. Don't take that as the golden answer because even G.E. tech support doesn't know. It could be the control board, but I haven't seen that yet. G.E. always recommends replacing the inlet thermister, which is accessed through a little cover on the back. Good luck & welcome to the wonderful world of complex electronic appliances.
Jan 27, 2008 | GE Profile Harmony DPGT750EC Electric...
GE dryer shut off prematurely and now won't start
I'm having the same problem with my GE dryer. I think that it may the safety thermostat receaching maximum temperature and shutting the dryer down.
I'm currently researching this problem now.
Dec 05, 2007 | Zanussi TC7102W Electric Dryer
Roper REX3614KW Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
