Question about Canon PIXMA MP830 All-In-One InkJet Printer
Sheet feeder isn't working
I have a canon pixma mp830, mac osx. all of a sudden the sheet feeder has stopped working. i've restarted the machine, taken the paper out, etc. the sound that indicates it's trying to get the paper into the line is heard, but nothing happens. don't see anything moving, don't know if one should is there a manual feed slot? can't find it in manual. thanks, roger
  • Anonymous Nov 10, 2007
    After about 12 month of service the paper feeder for white paper stopped working. No printing anymore.
    But: when I run the self diagnosis progam the feeder seems to work.
  • Anonymous Nov 14, 2007
    The paper feed makes a clicking sound when switched on as if there is a loose part. When trying to copy, the feed accepts about a quarter of the page but does not make any copy. It works perfectly when placing a sheet for copying on to the platen.
  • 186 Answers
Which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
Posted on Jun 29, 2007
Error message to "Load Paper"
Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
Nov 30, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
This error indicates a paper jam. Something is restricting the paper path. Check the paper path from the Automatic Sheet Feeder (ASF) side, raise the cover and visually check the paper path. Try running a thicker sheet of paper through the printer (card stock will work) to see if you can dislodge the restriction.
Let me know if this clears the problem. If not we can try something else. Thanks.
Feb 27, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How to uninstall Canon MP830 drivers on a MAC OSX
Go to system preferences (in the apple logo top left of your screen) and click 'Print & Fax'.
Select the printer then click the minus (-) key
That will remove your printer
Jul 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 has error code 6B00 after paper jam
6B00 is Paper feed position error.Look for any pieces of paper in sheet feeder.
Dec 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I run a Mac OSX Leopard My Canon MP830 seems to be having a paper feed problem. I also get the Error 5010. This happened right after using the scanner. It starts to work ok, but then a noisy clicking...
Is the message 5100. Paper jam? This indicates that the printer head carrier is being interferred with. Open the cover and check the slide bar and the paper path to see if there is something obstructing movement. If the drive belt has slipped it needs to be reseated.
Apr 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp730 driver for macX
Canon Pixma MP730 driver works in leiu of the regular MP730 driver
Jan 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer not printing
Error code 6A00 is the ASF( auto sheet feeder unit) unless you want to pull it apart to re-time the gears you will have to take it somewhere that can do the repair for you
Nov 05, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
149 people viewed this question
Clive
Clive
old marine
old marine
