Question about Bissell PowerForce Turbo Helix Bagless Upright Vacuum, Black/Red, 68C7
Bissell 68c7 won't start+switch
Bissell Power Force Helix Turbo 68c7 will not start. Foot switch seems to be floppy.
Delphi51
  • 33 Answers
SOURCE: bissell power steamer turbo
Mine does that, too. Pushing down and wiggling the tank usually gets it going. Also, it doesn't seem to work when the soap bottle is low, even when the soap is turned off. I fill the bottle with water. It is easy to take the top off. Mine has just 6 screws. Then you can see all the tubing and parts. For example, you can unclip the nozzles and see if water flows. Try blowing through the nozzle to see if it is plugged. Some people say the heating unit in the handle plugs up, particularly if you put soap in the water tank. I haven't dealt with this, but it should be easy to open the handle and bypass the heating unit.
Posted on Sep 11, 2007
reddevil6
  • 1673 Answers
SOURCE: bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
Posted on Jan 09, 2008
  • 4 Answers
SOURCE: Bissell Lift-Off Turbo power outage
We experienced the same thing. There are several filters on the vacuum cleaner that need to be cleaned out regularly (monthly in the user's guide). But the reason ours was shutting down is a protective circuit that cuts power for 30 minutes to avoid burning up a motor when there is a clog. Our clog was in the hose on the back of the cannister. One end of it can be lifted out of the bottom. The other end locks into place on the top (by rotating the ring on the end of it). It is the path for the hair and debris to the bagless cannister. We found that the top end of that hose was clogged with hair preventing anything from going into the cannister. So if your cannister is not filling, that's probably your problem. Easy to remove the hose and it's only about 18" long, so find something to stick through it and force out all the clogged debris and hair. Good luck!
Posted on Jun 07, 2009
Wins411
  • 166 Answers
SOURCE: I have a Bissell Turbo - Powerforce Model #6585C - I want to know
First go here:
http://www.bissell.com/searchresults.aspx?searchtext=9500&mode=userguides
This is the PDF of the user guide. Start on page 18 and 19 and this shows how to change the belts.
Posted on May 03, 2010
heatman101
  • 43501 Answers
SOURCE: Info on how to operate a Bissell Turbo Brush Model 7901-P.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
345erw
Posted on Sep 30, 2010
How do I clean the filter
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
Sep 27, 2014 | Bissell 2 Sets Bagless Upright Vacuum...
I just replaced the belt on my bissell powerforce helix turbo and now I cant get the vacuum to move forward only backward
The plastic piece on the bottom may not have been properly seated before installing the screws.
Apr 20, 2014 | Bissell Vacuums
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Turbo Helix Bagless...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Turbo brush on bissell cleanview helix stopped spinning
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 07, 2012 | Bissell Cleanview Helix Deluxe Bagless...
It won't turn on
Have you checked the cords for a possible break preventing the machine from getting power. Use a AC volt meter to diagnose this. Many times the wires at the plug that goes in the wall break and it is the most common problem. Other issues are a defective motor and a defective on/off switch.
Jan 15, 2012 | Bissell Cleanview Helix Vacuum
I have a Bissel Cleanview Helix, model #82H1. The
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell Cleanview Helix 82H1 Series User Manual
Ava B.
May 29, 2010 | Bissell 35755 CleanView Bagless Upright...
Bissell PowerForce Turbo Helix Bagless Upright Vacuum, Black/Red, 68C7 Logo
83 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
