Question about Dryers
Where do I find the heating element in my hotpoint dryer
Hotpoint dryer Hi we have my dryer taken apart completely and still cannot get the drum out. The three screws located in the center of the drum will not move I cant get them to budge. Am i missing something?
  • 135 Answers
At the back of the dryer there is a small plate secured by 2 screws. Behind this you will see the spindle secured by a solid wire curled around it. remove this wire and the drum can then be removed.
Hope this helps &thankyou for using Fixya.
Posted on Jan 19, 2009
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
No heat output
in electric dryers,no heat is often caused by burnt-out heating elements,then overheat thermostats,and lastly operating thermostats.this assumes power and drum operation are nominal. some elements are in a "containment vessel". the really tough ones are behind the drum WITHOUT a separate enclosure. as it. is with dryers,the drum belt is best untightened by undogging it from the idler pulley.
Oct 12, 2012 | Hotpoint NVL333EY Electric Dryer
When i press the start button on the tumble dryer it blows the fuse in electric box
Greetings,
This dryer could have several different things wrong with it and needs to be taken apart to check it....It could be the heating element shorted to ground or the dryer motor shorted out to ground...It could be an over heated wire that melted into each other..you need an understanding of how to check circuits if the obvious isn't seen...i.e. broken element or burnt wire....Bruce Denton
Jan 04, 2011 | Hotpoint Dryers
How do I change the element on Hotpoint Dryer
your model # appears to be in complete. if you have the two strand type located behind the drum, you can buy a restring kit. will have direcions with part. take model # and order at repairclinic.com
Jan 31, 2010 | Hotpoint Dryers
No heat coming in drum
Probably a bad heating element (which he will have to take it apart to see).
Sorry!
May 19, 2009 | Dryers
Hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Apr 23, 2009 | Hotpoint Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
