Question about Muratec MFX-1430 Copier
Calibrate muratec mfx 1430 touch screen - Muratec MFX-1430 Copier
4 Suggested Answers
SOURCE: Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Posted on Sep 25, 2008
  • 1218 Answers
SOURCE: reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Posted on May 27, 2010
  • 1218 Answers
SOURCE: Muratec MFX 1430 Fax / Printer / fax does nto turn on.
UNFORTUNATELY YOU MAY HAVE LOST A PCB. IF THERE IS NO DISPLAY AT ALL YOU WILL PROBABLY NEED A SERVICEMAN. WOULD STRONGLY SUGGEST YOU GET EQUIPEMENT LIKE THIS ON A "SURGE-PROTECTOR". ITS A LOT EASIER TO REPLACE A $25 SURGE PROTECTOR THAT POSSIBLY HUNDREDS FOR A NEW PCB.
Posted on Jul 12, 2010
Testimonial: "Thanks for your response. I was afraid that was going to be the problem. "
Can you adjust the edge erase area around the border of the copies printed out on the MFX 1430. I would like to reduce it,because it cuts off some of the letters and numbers
Unless someone has changed it(made it larger)...factory default is 2mm void at the edges and you can't make it any smaller than that.
Nov 28, 2010 | Muratec MFX-1430 Copier
Does anyone know of a reliable source to get Muratec Fuser assemblies repaired or at least a source to purchase the parts? Specifically the MCX 1430 or 2050. thanks,
The 1430 and 2050 fuser units are differently "geared" due to the speed difference the 2 machine run at. To find a local dealer who can help with parts...give Muratec Tech Support a call at 1-800-359-7035 and they can likely tell you who to contact in your local area.
Sep 01, 2010 | Muratec MFX-1430D Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Jul 08, 2010 | Muratec Copier
I need a lid hinge the number on the side is 07do4l do you know where i can get this part
The lid hinge on the mfx-1430 which "tends" to be the one that breaks is part #Z906461000 which is the hinge on the L.H.S. as you are looking at the machine from the front. Contact any copier dealer locally who deals with Muratec and they should be able to provide the part.
Feb 10, 2010 | Muratec MFX-1430 Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Reset drum counter on a muratec mfx 1430
Sep 15, 2009 | Muratec MFX-1430 Copier
My computer does not detect MFX 1430 printer. I think I need the usb driver for the usb cable.
Yes you will need drivers to run a "Local" set-up which is what a usb connection is called. Install drivers BEFORE connecting usb cable. You can download drivers from Muratecs web site www.muratec.com
Jun 30, 2009 | Muratec MFX-1430 Copier
Jun 22, 2008 | Muratec MFX-1430 Copier
46 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
CheckitRight
CheckitRight
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
