Centrex ctar65gw outdoor unit specs - Heating & Cooling
4 Suggested Answers
SOURCE: Centrex CTAR65GW reverse cycle air con. missing remote control -
Thanks for your response, but we finally found a universal remote through Andca Airconditioning in Rosebud, Victoria. It cost us $90 and worked a treat.
Thanks and regards
Wendy
Posted on Jan 27, 2009
BIKER T
  • 909 Answers
SOURCE: centrex a/c keeps shutting off every 15 minutes ( split system)
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
Posted on Feb 02, 2009
heatman101
  • 43501 Answers
SOURCE: Anyone know where I can
I buy alot of those motors through www.grainger.com
match up the hp, rpm, shaft size, mounting, voltage, etc... this can take a bit, but you will find a motor for partically anything there...
heatman101
Posted on Aug 11, 2010
Malfunction display saying outdoor sensors. Everything checked out fine with the unit and the display board, so the problem is with the communication between them. Any answers?
Usually an outdoor sensor is a thermistor. You need to check the resistance range on the thermistor to see if its withing specs. If it isn't you will get an outdoor sensor error.
In all likely hood the sensor needs to be replaced.
Oct 05, 2014 | Carrier Heating & Cooling
My centrex air con shoes e6 and e7 and does not work why
HELLO,
I HAVE A CENTREX AIR CON UNIT AS WELL.. I HAVE NOT TURNED IT ON SINCE LAST SUMMER.. THE REMOTE IS WORKING BUT I'M NOT ABLE TO TURN THE UNIT ON.. I ASSUME IF IT'S ON A SMALL LIGHT SHOULD COME ON.
WHERE IS THE POWER SWITCH AND IS THERE A MANUAL WAY TO TURN IT ON FROM THE UNIT?
THANKS,
B
Nov 30, 2012 | Heating & Cooling
Anyone know where I can get a fan motor for the indoor unit of my centrex CTAR65GW split system air conditioner. i think the motor may be generic for most of the cheaper split air conditioners. Denis
heatman101
Aug 11, 2010 | Heating & Cooling
I have a Centrex air keeps tripping breaker
The first thing I would check is the outdoor unit coil and see if it is restricted(dirty). If that is the case then you can wash it off with water(make sure you shut the power off to the unit first). If the outdoor coil is restricted and has little air flow thru it ,it can't get rid of the heat from the space and the compressor will draw over amperage and trip the breaker.
The next thing to check is if the outdoor fan is running. If the fan doesn't run it is the same as the restricted coil, it can't get rid of the heat from the coil. Check these things first then we can go from there! Thanks!!
Nov 22, 2009 | Heating & Cooling
Centrex a/c keeps shutting off every 15 minutes ( split system)
Feb 02, 2009 | Heating & Cooling
Not blowing cold air
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Jan 20, 2009 | Heating & Cooling
Thanks and regards
Wendy
Jan 07, 2009 | Heating & Cooling
Centrex air conditioner keeps cutting out and turning off
Ihave the same unit, and the same thing has happened to mine, I will be fixing mine by replacing the complete unit with a known brand.
Nov 22, 2008 | Lands Phones
Desperatly needing code for Centrex television A.S.A.P
finally i got a remote with the centrex code,.. Its 0056 bye
Apr 04, 2008 | Televison & Video
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
