Question about Ultra ATI Rage 128 Pro Graphic Card
Display problems My computer won't allow me to change the settings for my monitor. Some icons on the computer, when opened are not displaying properly (black boxes, etc.). It worked properly before now some program icons when opened, don't display properly. Things such as security codes not showing up and no graphics where they should be.
  • 1,602 Answers
THE DRIVERS MAYBE CORRUPTED AND YOU NEED TO GET IT UPDATE OR RE AVTIVATED
Posted on Mar 02, 2009
My mointor just flashes different colors and won't turn off
If you can find a setting for DDC/DI and turn that OFF, this could solve your problem (it did for me).
Description of the setting is included below, but put simply it allows your monitor to communicate with your computer and make adjustments.
From wiki: The Display Data Channel or DDC is a collection of digital communication protocols between a computer display and a graphics adapter that enables the display to communicate its supporteddisplay modes to the adapter and to enable the computer host to adjust monitor parameters, such as brightness and contrast.
Mar 04, 2013 | Hyundai Electronics W240D LCD Monitor
When I shut my laptop monitor goes off and won't come on until I open laptop again?
Change display settings in energy management to NOT turn off when closing the laptop
Oct 20, 2012 | Apple Cinema Display 23" HD Monitor
HP (Altec Lansing) monitor is displaying sideways, my friend lent me her laptop
Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
Option One:
Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
Option Two:
If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
If neither of the previous options help, try the following procedure.
  1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
  2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
  3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
  4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
  5. Click "OK" to save changes and exit out of any open properties windows
Jan 30, 2011 | HP Computers & Internet
After turn on of computer all pictures in the monitor are face down
try this...
Option One:
Option Two:
Option Three:
  5. Click "OK" to save changes and exit out of any open properties windows.
DO REMEMBER TO VOTE FOR THIS ANSWER IF IT HELPS...................
Jan 18, 2011 | Computers & Internet
Screen display is sideways
Hi all5r_mine,
Based on your situation. I suggest trying the following options:
Upside Down or Sideways Monitor Display
Problem Description:
The user accidentally pressed a keyboard combination that turned the entire monitor display upside down or sideways. The user cannot recall the keyboard combination that caused the problem and has no idea how to rectify the display.
Possible Solutions:
Option One:
Option Two:
Option Three:
Navigating through menus and choosing options when the display is abnormal is difficult but certainly not impossible.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Acer Computers>Laptops Aspire 5610-2013 PC...
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
When i start computer there is no display on the monitor. when i restart computer many times(4 to 5 times) then display is shown . i also changed my RAM
How about try changing your display setting, go to control panel. Double click display icon, click settings, click advance and monitor. From your monitor settings change screen refresh rate to 60 Hertz and click ok and ok. Try to restart your computer and observe.
Sep 22, 2010 | Intel Pentium Dual-core Processor E5200...
So I hooked this moniter up to my hp and all I get is two blinking lights
One monitor serves as the primary monitor, and this monitor displays the Logon dialog box when you start your computer. In addition, most programs will display windows on the primary monitor when you initially open them. You can select different screen resolutions and different color quality settings for each monitor. Multiple monitors can be connected to individual video adapters or to a single video adapter that supports multiple outputs. To configure the arrangement of multiple monitors:
  1. Click Start, and then click Control Panel.
  2. Click Appearance and Themes, and then click Display.
  3. On the Settings tab, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  4. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
NOTE: The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Change Primary Monitor
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to designate as the primary monitor.
  2. Click to select the Use this device as the primary monitor check box. Note that this check box is unavailable when you select the monitor icon that is currently set as your primary monitor.
View Same Desktop in Multiple Monitors
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to use in addition to your primary monitor.
  2. Click to select the Extend my Windows desktop onto this monitor check box. After you enable this feature, you can drag items across your screen onto alternate monitors. Or, you can resize a window to stretch it across more than one monitor.
Move Items Between Monitors
  1. On the Settings tab of the Display Properties dialog box, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  2. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply.
  3. Drag an item on your desktop across your screen until it appears on the alternate monitor. Or, you can resize a window to stretch it across more than one monitor.
Using DualviewOn many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor that is attached to the first video out port. Once you attach the second monitor and turn on your computer, use the Display tool in Control Panel to configure your settings, just as you do with multiple monitors. You can use Dualview with docked or undocked portable computers.
Mar 08, 2010 | HP A4331D 20" CRT Monitor
Connecting 2 monitor and tv
Multiple monitors overview On many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor attached to the first video out port.
Once you attach the second monitor and turn on your computer, use Display in Control Panel to configure your settings, just as you do with multiple monitors. Dualview can be used with docked or undocked portable computers.
Arrange multiple monitors To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Jul 29, 2008 | Computers & Internet
GIGABYTE X1300PRO GRAPHIC CARD
  1. Open Display in Control Panel.
Notes
Nov 19, 2007 | Computers & Internet
Computers & Internet Logo
254 people viewed this question
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
just-ice
Alun Cox
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
