Question about Neff U1661 Double circotherm super Electric Oven
Neff u1661 control unit
Does anyone know where. Can get a control it for a u1661 control unit which blew when a bulb blew.
SOURCE: Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Posted on May 08, 2008
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
SOURCE: neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Posted on Nov 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Posted on Nov 21, 2008
barkencoa
  • 3463 Answers
SOURCE: My Neff U1661 has packed
It should fit without any problem most oven housings will accomadate most ovens, those in production now, and those made 10 or more years ago.
Posted on Nov 17, 2010
How to replace knobs on u1661 oven
Just pull them off and replace. Its that simple.
Apr 27, 2012 | Neff U1661 Double circotherm super...
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
Hi.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Neff oven door (U1661)
Oct 20, 2008 | Neff U1661 Double circotherm super...
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Neff oven U1661 shows fault code -5-
Sep 17, 2008 | Neff U1661 Double circotherm super...
Apr 27, 2008 | Neff U1661 Double circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
43 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
