Question about Boating
Suzuki DT 75 outboard motor oil injection
Operators manuel
  • 5501 Answers
SOURCE: 1994 Suzuki DT 9.9c outboard engine oil light on, but engine not.
It sounds like the oil cutout switch is bad. It is suppose to save your engine from running low on oil. Several things. Engines that use these switches may have two fill plugs. One is higher than the other meaning it has to have more oil to top it off. Next is the angle of the motor when it is on the boat. All the oil will go to the low side of the engine. If the oil shutoff is on the high side it thinks you are out of oil.
Posted on Jun 11, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
SOURCE: need to know year of outboard motor
1992
Posted on Jul 02, 2009
  • 86 Answers
SOURCE: 2003 yamaha 115 outboard motor that dies when
I would check your fuel lines from the tank all the way to the fuel pump. It seems that you might have a pinched line somewhere. You can also bleed the fuel rail with the schrader valve on the end of the rail. If that wont fix it then you probably have a weak fuel pump.
Posted on Aug 09, 2009
How to adjust oil injection on 140 hp yamaha outboard motor
talk with a yamaha outboard service center as generally the oil injection is set to the fuel usage to maintain the correct ratio in the mix
Apr 14, 2017 | Yamaha Boating
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
May 22, 2016 | Suzuki Motor, Power Trim, DF60-70 98-00,...
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Jun 19, 2010 | Boating
Where can I get a user manual for my Suzuki
sorry suzuki wants you to purchase a manual so there is no free one online that I can find. Here is a link to clymer manual. click here
Oct 27, 2009 | Boating
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Jun 01, 2009 | Boating
Boating Logo
105 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
