Question about Vacuums
Vax mach air blowing noise
Loud blowing popping noise from top filter
3 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Posted on Oct 16, 2008
SOURCE: i cant figure out how to change the belt on my vax
trying to work out how to fix my vax 5 belt
Posted on Aug 20, 2011
There is a loud popping noise coming out the top of my upright vaxair Hoover
usually loud sound is carbon brushes reached their limit in length shortness and brushes are sparking against the commutator
Jan 04, 2018 | Hoover Vacuums
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
The filter camber on top pops and the air stops coming thru the whole vacuum cleaner. checked filter and washed said filter. Still happens. It is a loud pop and the air noice is loud. It pops when I pull...
I'm sorry to hear you're having difficulties with your DC15. From what you've described, it sounds as if the relief valve is activating - if you've already washed the filter, it may be activating due to a blockage in the machine. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=813&product=DC15-SY-STD
Although I note you've already washed the filter, you may want to take a look at the video below to make sure you've cleaned it as recommended. In normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Jan 23, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Electrolux Vitesse petlover 1700w loud noise
So all that is left is a blocked filter, ie paper like the ones in a car, remove- wash bash out the dust etc- I use compressed air to blow them oput backwards. If it is bagless there has to be a filter somewhere otherwise everything comes straight out.
I would also be looking at hose obstruction and leaks in the body of the system - assuming it still sucks well enough. I often remove the hose and drop a heavy steel rod or the like down to shake out the hose. I have a lot of this with saw dust on the shed cleaner.
If it were mine I would then pull it apart to look for bockages or bits caught in the fans. But do not do this if you are not confident of reconstruction safely or if there is a warranty available.
Dec 28, 2011 | Electrolux Vacuums
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi.
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
241 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
