Question about Stanley Garden
I have a Stanley Router model .02 motor 9008 need brushes for it where can i get parts?????
2 Suggested Answers
kamakani
  • 104 Answers
SOURCE: Need a source to purchase motor brushes
http://www.masterparts.net/106890-01.html
I hope this helps out.
Posted on Jun 19, 2009
Who makes the electric motor for the Stanley 2.8hp vacuum
Almost for sure it is produced in a no name contractor of parts.
Sep 06, 2016 | Stanley 2.8hp 4 Gallon Stainless Steel...
How do I fix my singer model 9008 pressure foot will not raise
Start with the manual: http://www.manualslib.com/products/Singer-9008-353399.html
You may be missing a screw. Clean and oil carefully looking for small bits of thread and lint. If this doesn't work, take it to an expert.
Aug 04, 2014 | Singer Sewing Machines
Need to view a Singer sewing machine manual for model * 9008
singer has a free pdf downloadable manual--the middle one
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9008) & click search
Jun 10, 2012 | Singer Sewing Machines
Need brushes for model 9531 buffer
I am in the business of repairing and rebuilding power tools and none of my brand name parts suppliers nor any of the sites I use to get off brand parts have your brushes available. I did find a part number 136506-02 that was replaced by part number 135948-03 but it shows it as a brush holder/brush assembly. My only suggestion is to find a tool repair center, ask if they have a stock of brushes and try to find a brush that will work in your holder. On many an occasion I have shaved the sides of brushes to make them fit into older model tools. You just have to be sure the top connector is compatable with your holder.
Feb 05, 2012 | Tools & Hardware - Others
Need motor brushes for a stanley heavy duty 4'x24' belt sander. type: 497, model A, amps: hi-8.5, lo-7.0, volts 115, serial # 457244. thanks, tom
Hiya
I had the same problem, cannot find spares. I went to a local tool hire company and purchased two brushes (Part No. L41F10). You will need to shorten them by approx.1/4"", swap the springs and cut down the metal terminal to same shape as the original. A small 1/2 round file, junior hacksaw and about 15 minutes should get you going.
I am looking for a trigger (on/off) switch to suit my sander, if anyone can help I would appreciate it. Only other option seems to fit an inline switch to supply cable.
Jun 15, 2011 | Garden
Where can I find brushes for the remington model
Remington saw has gone out of business, and finding parts can be a hit or miss experience. Motor brushes in particular are quite rare, so you need to be resourceful in finding a similar brush used in other small tools. Visit a small tool repair shop or check with Ace Hardware (our local store has a whole display box of various sized brushes). If you do find something, buy more because these saws seem to eat brushes for lunch! Good luck!
Jun 07, 2010 | Remington Electric Chain Saw
I have Remington model # 107624-02 electricwhile using It would
I have had a similar problem with a couple Remington electric chain saws, including this one. I removed the motor, opened it up, and found the problem was burned out motor brushes. It can be quite a challenge finding replacements.
MAKE CAREFUL NOTE OF HOW ALL COMPONENTS FIT TOGETHER AS YOU DISSASEMBLE.
I took the motor with me and ended up finding some brushes with the same cross-section at a local electric motor repair place. I tried completely replacing the used brushes before, but always had trouble with either opening and re-closing the brush holder, or with trying to make connections to the existing wiring.
My most effective solution was to file the end of the burned out brush flat (it wears to a curve that fits against the comutator). Then I cut a piece of a new brush with the same cross-section as long as would fit inside the brush holder when inserted from the comutator end to replace the part that had burned/worn away.. I ended up with a piece between 1/4 and 3/8 inch long. This fits flat end to the filed-down flat end of the burned out brush.
Once carefully put back in place and reassembling the motor and saw, I ran the motor with no chain for a minute or so to verify the fix and give the brush a chance to shape itself to the comutator.
This is not necessarily a permanent solution. But I can repeat the process as often as needed until some other component wears out enough to justify replacing the entire unit.
I really like NOT messing with gas engines and do a lot of heavy cutting on logs moved nearer to the house.. But the weak link on every electric I have had has been the brushes eventually burning away.
NthBob@aol.com
Mar 28, 2009 | Remington 16" Electric Chain Saw
Carbon motor brush source?
unfortunatly the only way you could purchase the carbon brushes is from a vacuum parts dealer directly. the brushes will most likely end up costing you close toth price of a new motor anyway. sometimes its best to just get a new motor as the newer designes rotate teh brush much faster for better cleaning.
Oct 25, 2008 | Filter Queen Majestic Canister Vacuum
Garden Logo
47 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
