Question about Frigidaire Dishwashers
ER Code Flashing. Frigidaire FDBB4365FC3 about 3 yrs old. Flashing lights on display. have reset the breaker multiple times. Got it to wash again but stops about midway with ER on display as well as Washing, Drying, Clean S flashing. Guy C.
  • 409 Answers
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
SOURCE: 6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Posted on Apr 08, 2009
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
  • 77 Answers
SOURCE: The green clean light is flashing on my Kenmore
You may just need to reset your control board. Go to the link and it will explain how to reset the control board as well as explain what might cause the issue and how to fix it.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good Luck
Posted on Mar 06, 2011
oldTech2332
  • 2341 Answers
SOURCE: frigidaire gallery FGHD2433kw1 error
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Posted on Aug 23, 2011
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
FPHD2481KF1
Thank you for your post, nansie Bento!
Based off the information you have provided your Frigidaire dishwasher is flashing "ER clean S". That error stands for a membrane switch failure, which means that your main control board has detected a key stuck or pressed in for more than a minute. You can push all the buttons down to attempt to locate the key that is stuck. It could be a potential issue within the keypad or main control board. You could try to clear the error code by resetting your appliance, which can be done by flipping the household circuit breaker for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 24, 2014 | Frigidaire Dishwashers
4yr old Frigidaire, green flashing ER light and red flashing washing/drying and red flashing clean/S. model# PLD 4555RFC3. Also green flashing china/crystal and red flashing rinse/low, start/delay doesn't...
Good Afternoon Sandra, thank you for your question!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 21, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
hi there,
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Dishwashers Logo
67 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
