Question about Elna 2007 Mechanical Sewing Machine
Elna 500 electronic will no longer zig-zag stitch
I set stitch selector to zigzag or 1...then set stitch width dial between 2 and 4...the set stitch length dial between 1 and 3 But all the needle position does is to remain in the straight stitch position. The machine was purchased in 1984 and has recently been oiled as directed and lint removed. It was sewing beautifully just last week. Help!
2 Suggested Answers
  • 1788 Answers
SOURCE: It sews straight just fine.
Get a copy of your manual for $10 at www.sewingmanuals.com and you can check out the problem. Kind of hard to help when the machine is not there.
Posted on Sep 19, 2010
How do I turn the selection dial to zigzag on my Elna Super
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
Nov 06, 2011 | Elna 2007 Mechanical Sewing Machine
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Jun 11, 2011 | Necchi 3537 Mechanical Sewing Machine
Don't remember how to set it to do a zig-zag stitch
Generally on most machines you would set the stitch length dial to 2, and stitch width dial to 2. And the stitching selector to the zig zag icon.
If you give your make and model other experts may provide more specific info for your machine.
Jun 04, 2011 | Sewing Machines
My Elna SP suddenly stopped making the normal stitches regardless of whether I turn the stitch guide to "normal," "zigzag," or "overcast" mode.
Have you also turned the stitch width lever to 3 or 4 to form a swing needle type stitch?
Is this a Lotus SP or a Star Series SP? They should both have a stitch selector, a stitch width dial and a stitch length dial. Stitch width usually 3 or 4 and length usually at least 2 for a zig zag or overcast stitch. Also check the needle position dial, have you perhaps moved this off centre and not moved it back?
Mar 03, 2011 | Sewing Machines
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Aug 23, 2008 | Elna 2007 Mechanical Sewing Machine
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Elna 2007 Mechanical Sewing Machine Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
