Samsung hlt6156wx/xaa tv won't power on
Samsung tv will not power on. It was working fine this afternoon but for some reason will not power on any more. It does a weird cycle and nothing.
  • 304 Answers
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Posted on Jul 16, 2009
  • 73 Answers
SOURCE: dot all over tv samsung hls4266wx/xaa
You need to replace the dmd board.In some cases it is more cost effective to replace the entire optical engine which includes the dmd board,lamp,ballast and color wheel for about the same amount of money and is easier to install.
Posted on Aug 22, 2009
SOURCE: blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Posted on Apr 22, 2010
  • 8457 Answers
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Posted on Aug 02, 2010
SOURCE: samsung hls4266wx/xaa tv. tv
I put a lamp in to my Samsung HLS4266WX/XAA, but when I actually took it apart for the Bulb replacement which I have done twice now. I found where that switch is, that gets pressed when you have the back cover to the bulb screwed in was hanging, and I can get the new bulb and my replacement bulb to work for about 15 secs, and at one point it was working really good. Can anyone help me with this problem, cause Im getting frustrated. It seems like a simple fix,but its almost like the bulb I ordered is not as good as my other replacement bulb.Its from MWAVE.com, anyone heard anything about this company? Please help if you can, id really appreciate it.
Joe Red
Posted on Jul 01, 2011
My samsung tv LNT4669FX/XAA screen is blank but the tv and backlight work. how do i fix the tv?
It sounds like the screen may have failed, that means a new TV will be needed.
Feb 24, 2017 | Samsung Televison & Video
Samsung hlr4667wx/xaa
can be this one Samsung BP47-00027A
or this one Samsung BP47-00021A Lamp Ballast would say it is this one 00021A as its on its listings. http://www.ebay.com/itm/Samsung-BP47-00021A-Lamp-Ballast-/331036842455?pt=US_TV_Boards_Parts_Components&hash=item4d135559d7 54.11 USD.
Mar 28, 2014 | Office Equipment & Supplies
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
I have a Samsung 61"
Sir the lens of your lamp is just dusty try to clean it with microfiber cloth but remove ac plug to the main, then wait for the lamp to cool down before cleaning the lens or try to check user manual. Good day and best regards.
Sep 06, 2011 | Samsung HL-T6156WX 61 in. TV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
