Question about Homedics Audio Players & Recorders
How do I undo an alarm on my HoMedics Unwind docking speaker? It arrived with Alarm 1 and Alarm 2 set and I want to remove alarm 2
I understand how to "change" the existing alarm that is set, but I want to turn off the Alarm 2 forever. How do I do that?
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
SOURCE: turning off alarm for jims-225
Hold the snooze button for 3 seconds.
Posted on Dec 30, 2008
  • 5 Answers
SOURCE: Lost the manual for my nexplay alarm clock/ipod dock
Setting the Clock:
1. Press the SET Button 3 times until all digits for the main clock are flashing.
2. Press Skip forward and back to change the hour and Volume up and down to change the minutes.
3. Press the set button once to save.
Posted on Oct 19, 2009
SOURCE: How do I set the clock on Accurian IPod docking
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Posted on May 03, 2010
SOURCE: How do you set the clock and alarm on the Starlite
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Posted on Aug 06, 2010
Anyone know how to set clock on iCoustic A-101 iPod Dock/Clock Radio?
Ok I have this figured out, if it's the A-101a dock, with the power turned off, double click the MEM/SET button, that will get you there! Choose from format first (24/12 hour time) then click again for hours and minutes. Took me ages, just figured it out!
Jul 20, 2012 | Audio Players & Recorders
How do i set the alarm
Select on the top AL1 or AL2 depending on which alarm you want to set until that is selected on the screen in the upper right corner. Then press the AL Set button twice. Turn the +/- knob until you have selected the right hour. Make sure you set AM or PM when scrolling through (PM has an indicator, AM does not). Press the AL set button again. Then scroll through with the +/- knob to choose the minutes. Then press the AL Set again to make that your alarm.
May 05, 2011 | Homedics iSoundSpa Clock Radio with...
Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
Dec 21, 2009 | Starlite Next Play Clock Radio with iPod...
Setting the Clock:
Sep 11, 2009 | Starlite Next Play Clock Radio with iPod...
Cannot set up the arrival alarm to a point
If you set your arrival alarm to .001 you are trying to hit a very small circle, only 6' in diameter and the odds of actually reaching that point are incredibly low so it's not likely the alarm will go off. Try setting your arrival alarm to .100 just to see if the arrival alarm works better.
When you set alarm to 15 second arrival you should see and hear an alarm, however, the slower you are going, the smaller the arrival circle gets, which means its gets harder to hit the area that triggers the alarm. 15 seconds is the default setting and I have found that it works fine at normal cruising speeds. If you are traveling very slowly, try bumping the arrival time up in 30 second increments to see if you can get an alarm.
When the alarm does go off, it is a very faint double beep which is hard to hear over the sound of wind and engines. I don't remember exactly how the visual arrival message appears but it is also very subtle. It appears either as a change to the menu bar at the bottom of the screen, or as a message box on the screen that dissappears very quickly. When I use that model I frequently miss the arrival alerts.
Jan 08, 2009 | Garmin GPSMAP 3210 GPS Receiver
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
Set the alarm
Hold down Alarm Set for about 5 seconds until the time flashes, then just press the hour and minute buttons until the time you want is shown. Remember that the pm light WILL come on if you need the alarm set for the evening.
Sep 15, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
