Question about Pentax Optio S50 Digital Camera
Water Damage I have a GE A730 digital camara. My sister accidentally dropped it into a bowl of water. I got it out within like 3 seconds of it falling in their but the screen will not work. I hear putting it into a bowl of rice would help but it doesn't seem to be helping anyone have any ideas on what to do?!?
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here :
rate if useful please !
Posted on Jan 17, 2010
I dropped camra in water any way to dry it out
I dropped my cell phone in water one time and somebody told me to put it in a bowl and completely cover it with dry rice and believe it or not that worked. Don't usually answer camera questions but thought I may try to help. Give it a shot and I hope it works for you.
Jan 30, 2012 | Cameras
When a device falls into water/when you are drenched.
Water in an equipment.
It is quite common that often we have one of our hand held devices accidentely fall into water leaving us into a loss of data and money in a matter of seconds.
Water is a great enemy as it conducts with the impurities present , specially when the circuit is sensitive and highly intergrated.
what ought to be done immediately as you retrieve the device is to remove the power source- the battery. Now allow it to dry but we need to assist the process , make it clear off contacts so as no intercircuit shorts prevail.
But to make an attempt remove the covers and wash well with petrol the printed circuit board both sides making sure that the plastics or display does not come into contact. This is purely to remove all trapped moisture within the pin configurations. Now use a dryer( hair dryer) very mildly so as to take off trapped water inthe through holes of the double sided board.
Repeat the job after few hours ,use a soldering iron if there are signs of smoky lead ( traces of battery voltage in electrolysis)
If there is fumes coming on when soldering iron is touched on spots repeat till you are sure of a total dry PCB.
Use a tooth brush to clean the PCB so that all points are scrubbed well.
Finally the few seconds that water got in is critical as water conducts, the inter circuit short in the first few seconds can damage critical circuits.
So you must be really lucky to get the device back in action.
on Sep 17, 2010 | Cell Phones
Lens shutters are stuck
If you have recently dropped the camera or exposed it to excessive dust/sand or dirt the shutters guide tracks may be jammed and unable to move. I would advice taking it to a camera repair shop, and to avoid opening the camera on your own as it may cause further damage/voiding of warranty.
Jan 26, 2012 | GE A730 Digital Camera
I let my camara fall in the sea their was no
Sorry but saltwater is the worst thing after fire or total crushing that any electronic device can be exposed to. Salt causes physical and chemical damage which is near impossible to reverse. You might not have seen any water inside the camera, but it only takes a tiny amount to destroy a digital camera.
Your camera may look ok, but it's a write-off. It's impossible to remove all residual salt which will continue to corrode circuitry inside the camera. Any tiny pockets of trapped saltwater are eletcrically conductive and will cause electronic faults, any condensation which occasionally gets into all cameras just dissolves trapped salt to effectively become seawater.
The only hope would have been to immediately remove the battery and memory cards and then to immerse the camera in de-ionised water, but even then the camera would likely have been ruined. Leaving it to dry out for two days has simply ensured that remaining salt deposits are now buried deeply within the components and absorbent materials used in the camera.
Sorry to disappoint you, but your only hope is that the camera was insured against accidental damage. Even then, the insurer may refuse to pay by arguing that your camera was put at unnecessary risk by not being in a waterproof housing.
I hope that my reply has still been of use to you; please don't forget to rate my answer.
Jun 22, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Orange light stays on and camera doesnt switch on
Water is second only to fire as being the most destructive thing you can subject your camera to.
Sorry, but it is a write-off. Even after drying out there will be residual and ongoing corrosion and retained moisture in internal components. This is specifically why your warranty is invalidated by such damage and why no camera repairer will even attempt a repair.
All you can do is to see whether you can claim for accidental damage on any insurance policies which you may have.
Feb 11, 2010 | Sony Cybershot DSC-S950 Digital Camera
My camara will not turn off a the button, I have
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | GE A730 Digital Camera
Why are there lines on my picture?
It has a shutter problem. The damage could be some dust particles between the shutter blades or the flex connector broken. Cleaning or otherwise replacement of lens unit will be the solution. It will be the camera technician's job.
Jul 12, 2009 | GE A730 Digital Camera
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
GE A730
Go to the website.
Search online with a search engine such as and key in "GE A730 software, driver download".
Here is the GE site (firmware is listed, but should have other software):
This should find what you need.
Aug 15, 2008 | GE A730 Digital Camera
Does the camera show up as a Removable Disc in Computer? You can call 800 730 6597 for further troubleshooting.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Jul 14, 2008 | GE A730 Digital Camera
Pentax Optio S50 Digital Camera Logo
56 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
