Question about Toys
Peg Perego Polaris 4 wheeler, won't move
The foot pedal or accelerator button that is pushed to start the 4 wheeler doesn't work anymore. It began a few weeks ago, it would go on and off like something was loose. But after I looked at it closer, nothing on the outside seems to be loose making me think a switch is bad or something of that sort.
Can anybody help? Thanks.
  • 1 more comment
  • 2415 Feb 03, 2009
    Intermittant start, switch is becoming tempramental. Can I buy a replacement switch?
  • lp_shorty Mar 17, 2009
    Same thing here, but we've only had it a week. It's goes like heck and then nothing! If we wait a minute it will go again.
  • clairewigs Apr 15, 2009
    I have charged it for 2 days and it just stopped going. It won't go at all. Battery was changed but still no life in it.
  • 350 Answers
May need battery or is just rusted!
I'd buy a can or two of WD 40 or similiar lubricant and spray it all over all the rusted metal I can get to then turn the wheels by hand as much as possible but that's just me!
Good Luck!
Posted on Jan 20, 2009
2005 GMC Savana 1500 electrical problems,acceleration
sounds like the BCM is going out on your vehicle .
Mar 03, 2017 | GMC Cars & Trucks
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Car will not accelerate
Further information will be required unless you would nlike a simple solution like.
Step one start said vehichle
Step 2 apply foot ti brake pedal and put gear selector in drive
Step 3 remove foot from brake pedal to accelerator pedal
Step 4 apply presure to accelerator pedal untill desired speed has been acheived
Note these steps will not work for manual transmission see section 37
For braking see section 22
Oct 13, 2013 | Hyundai Cars & Trucks
Car will not accelerate when gas pushed
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
I have a 2005 volvo xc90 t6 that is jerking when accelerating and in idle. It doesn't so it every time but is steadily increasing and began about 2 weeks ago. Check engine light will blink when on...
A blinking check engine light is the warning of an engine misfire that can cause damage to the catalytic converter. Check car by diagnostic tool and keep car well.
Oct 30, 2012 | Cars & Trucks
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
We have a Peg Perego John Deere Buck 4-wheeler that will no go. I thought maybe the battery was bad so I replaced it with a fully charged new one and it moved about 300 feet and then wouldn't do anything...
try jumpering the battery directly to the motors to see if the motors spin, if they don't then replace the motors as needed, if they do spin, then use a multimeter and check for 12 volts at the motor wires when the accelerator is pressed, if its showing no volts then work your way back to the shifter switch and check for volts, then to the foot pedal to find where the power isn't getting through then replace components as needed
Jul 08, 2017 | Peg Perego Toys
Brother CS 6000
With the foot pedal disconnected from the machine, push the button with the - and upward arrow. to stop sewing use the same button. It is the first button closest to the needle.
Jul 29, 2008 | Brother CS-6000
Toys Logo
796 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
