Question about Pool & Spa
I have an old pool heater gulf stream AE1000 the unit displays PrE and then displays HI and does not start up..it was repaired when I purchased the home with a new compressor ..any help ?
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
  • 760 Answers
SOURCE: Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Posted on Jul 18, 2010
  • 19 Answers
SOURCE: pool and spa heater will not turn on, low pressure on display
1) check the fuse on the transformer. You will get "low pressure" if the fuse is blown.
1a) remove front panel with flat head screw driver turning both big screws 1/4 turn clockwise
1b) look up under the 1 remaining front piece for 2 screws (one on each side). remove them and the 1 small panel slides down
1c) transform is directly in the center of this compartment
1d) red wire on transform has a black fuse case - twist open and check fuse (with an ohm meter it should read a dead short if it is working).
1e) if not working - replace with standard 250v 2a bus fuse.
2) it really is low pressure
2a) backwash pool or at least make sure pressure in filter take is not too high (high filter tank pressure == low water pressure in heater)
2b) if you have a bypass valve make sure it is not in bypass mode so most all pressure from the pump is going tothe heater
2c) right next to the transformer is the pressure switch. It has a small copper tube attached to the back and 2 wires in the front. Put an ohm meter across the two leads on this device. With the filter off it should be open, with the filter on it should be closed (short). If not either the copper tubing is clogged, the switch is faulty, or there is not enough water going through the heater. The amount of water that goes into the heater is adjustable and the water pressure switch is also adjustable. The owners manual explains how to adjust both but neither should need adjustment unless you have a special configuration (explained in the manual).
Posted on Sep 20, 2010
Where can i find a 2009 gulf stream amerilite le manual
Sandra, you may have to contact Gulf Stream, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gulf Stream Travel Trailer Owner Manual
http://www.gsowners.com/viewtopic.php?t=1702
RV motorhome and bus conversion mechanic resource
Manuals 1990 Newer RVing The Midwest Connection
Motorhome Recreational Vehicle Resource
Jun 28, 2016 | Gulf Stream 2009 Ameri-Lite 24BH
I would like to know how to turn on (run) 110 V for the water heater on a Conquest/Gulf Stream Travel Trailer?
Must be filled with water or elements burn out
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If water heater is plugged in and outlet has power... then water should be hot.
If no water inside tank, and tank is plugged in, and outlet has power, then element is burned out.
Gene
Sep 11, 2014 | Water Heaters
Water heater elements for 2006 conquest trailer
Remove the old element. Take note of the water heater make and model, i.e. Suburban SW6DE or Atwood GC6AA. You can find the replacement at your local RV parts department. I have even seen them at Lowe's. Or you can buy one online.
Apr 19, 2014 | Gulf Stream RVs
How do I get hold of a manual for a 2011 Gulf Breeze Sport 24 TRS that is in English? We are buying a trailer from someone in Quebec and everything is in French.
Try a Web search for the company that makes Gulf Stream products. Then you should find a Customer service number or a Search Box at the site which would make it possible to look up the Manual for your specific unit.
Sep 23, 2013 | Gulf Stream 2011 Gulf Breeze Sport 24 TRS
Ihave a gulf stream model no. GS1000-H-A purchased 4-25-09, what is the warrranty and do you have a copy of it. thank you.
was 1 year and that was 6 years ago there is none now but no we do not have a copy of it .
Apr 22, 2013 | Pool & Spa
Ok I cant find a model number on the heater, it has some info like Gulf Stream super heater, scroll inside and Titanium inside, 106,000 BTU The pool filter gets cleaned every monday by a pool service...
There are a few things that can cause a heater to not fire up. One is, if the flow sensor is not working. There can be sufficient flow, but if the heater cannot sense it, it will not light up. Make sure that there is enough flow. Another possibility is there could be a build up on the thermal couple or the burners that is interfering. Those do need periodic cleaning. You should be able to check the thermal couple without disassembling the gas line. I would not recommend tampering with the gas system unless you are confident with what you are doing. If you feel uncomfortable with something, it is probably a good idea to contact a professional.
Dec 16, 2009 | Pool & Spa
Hi I have a Gulf stream pool heater it is out of warranty of course, the fan does not turn on, the valves are open, the crazy thing is it has only been used a couple times, is there something I can check...
I am not certain for your brand but those I am familiar with would lead me to say try to clean your filter first.
If the heaters pressure activated safety seitch is open due to a dirty filter, the blower circuit is kept open as well. Backwash a sand filter, clean or even replace a cartridge depending on the age of the element, or recoat a DE system. With DE, you may need to clean the screen as well.
If none of that is apllicable, double check that the unit has power to it. Then check the blower circuit for power and/or an open switch. If you need to add comments, please be sure to include your heater model info as well.
Water flow lockout shows on the lcd. I can't cahnge the temp or re set it.
Press and hold down button for five seconds. If the flow problem is resolved, the heater will start up.
Sep 13, 2009 | Gulf Stream Pool & Spa
Starting a teledyne laars heater
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
76 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
