Question about Rainbow Technologies D4 Bagless Vacuum
D3C RAINBOW VACUUM POWER CORD - Rainbow Technologies D4 Bagless Vacuum
  • Rainbow Tech... Master
  • 18,391 Answers
If you mean you wont to replace the cord this video will show you
Posted on Jan 05, 2013
2 Suggested Answers
  • 61 Answers
SOURCE: Rainbow D3C electric Hose is broke
NO NO NO NO you have to get a new hose in this situation there is no other way around it. If you screw up just the littlest bit reattaching that hose a vacuum that uses water will QUICKLY let you know. Do yourself, your family, and your life insurance company a favor and buy a new hose.
Posted on Apr 15, 2009
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
I think the switch on the Rainbow E-series electric hose went bad. Is there an easy vway to verify it's the switch?
Hi, the only way, is to test that it has power at the swirch with a circuit tester or voltage meeter, or test the plug on the handle where you attach your power head power cord, or Rainbowmate power cord to.
If it does not get power there, then test that the switch is getting power.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 11, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Power cord leaks green oil
I suggest that you replace that corroding internally power cord. It may not be safe to use that power cord.
You can get your model information, at the bottom of your vacuum canister, from underneeth, where the water pan attaches to it.
It is probably a D3, or a D4
Thank you,
Ralph
Apr 10, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Apr 10, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow d3c beaterbar has low suction Vacuum itself has great suction
did you check the hose or the power nozzle it might have holes in it.
Jan 13, 2009 | 3M SV-497AJM Vacuum
Replace power cord
http://www.rainvac.com/schE1.pdf
Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Cleaning the flter on a e series rainbow vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=749568
Cleaning the filter on a e series rainbow vacuum
Posted by jonesjpc on Jul 06, 2008
This one does not have the tabs to depress as but has two screws in that area still doesn’t see how to get to the filter. Also I need instructions to replace power cord; On the E series single speed.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Rainbow E Series there really is no actual filter – the water is the filter for this particular vacuum. Before you remove the separator under the motor, place a newspaper or towel under the Rainbow without the water pan under the vacuum and then turn it on for a short period of time and spin the water moisture out of the motor and separator; then some of the maintenance is to remove the separator under the motor and clean that and then replace it. As far as replacing the cord there are screws under the Rainbow that need removal and then you can get to the end of the cord for replacement. The easiest way is to mark your wires and the cord will be much easier to replace otherwise check the owner’s manual for cord replacement or check with your local vacuum cleaner dealer in your area or to cal the cust serv @ the Rainbow factory for questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
No power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow D3C Low suction
You might check the carbon brushes on the motor, it could be that the motor is not running fast enough, which would mean replacing the motor. With the hose off, do you have good suction where the motor goes into the vac? If it is good there, then either the powerhead isn't working or the hose is clogged.
Dec 09, 2007 | Vacuums
Vacuums Logo
Top Rainbow Technologies Vacuums Experts
JoeVacs
Are you a Rainbow Technologies Vacuum Expert? Answer questions, earn points and help others
