Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Side-by-side Refrigerator Door Exterior Light has shortage
Refrigerator exterior light went off where the ice maker buttons are. I change the Bulbs when they blow, like I always do, and once changed, it would not come on. It seems like it may be a shortage. I looked at the bulb that I took out, and it did not look like it was blown. I'm not sure what to do at this point.
Thank you.
  • mizcee68 Jan 20, 2009
    Peyton32034- Thank you for that information. I will try this out to see if I can resolve this issue.
    I have another question for you the bulb is in the door, and it's hard for me to see where the bulb the goes, I have to kind of feel my way, when putting the bulb in. I can see the area, but it's back up in there where I can't actually look into, because where it is. I haven't ever taken anything a part.
    Do you have any more suggestion?
  • mizcee68 Jan 21, 2009
    Peyton- Thank you for your tips. You have been very helpful, and very detailed. I will try my hand at it this evening or at least by the weekend. I will let you know what happen.
    Thanks again!!!!
  • 410 Answers
The base of light bulbs vary from different manufactures and sometimes they do not seat all the way. unplug your refrig and try to look into the lite socket. you will see a brass tab in the bottom of the socket simply use a small pick or flat tip srew driver and pull the tab down a little bit then reinstall the bulb plug the fridg back up and it should work. thanks peyton
Posted on Jan 20, 2009
  • peyton thompson
    peyton thompson Jan 21, 2009
    its not hard to remove the disp cover if your game?
    1st remove drip tray, if your lucky you'll see 2 screws that seure the cover. if no srews look at the very bottom of the disp front and you'll see 2 notches, carefully pry the over off at these notches, i use a flat blade srew driver. once this is loose you'll see the wiring and switches there wil be either 2 screws or simple thumb latches that will let you pull this off and access the light socket.
    BE SURE TO UNPLUG THE REFRIG FIRST.
    GOOD LUCK. Peyton
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
The refrigerator icemaker does not make ice.
you have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Jan 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
