Question about Carrier Heating & Cooling
Blower Motor for Carrier Model FA4CNC036 leaking
Blower motor leaking oil
  • 15 Answers
SOURCE: how do i locate and replace the blower motor on # 58ZAV096
not sure if you have fixed the problem. There is a web site to get this motor... www.arnoldservice .com he should have the motor. I recomend a generic 3 speed mtr. you will have to cut the plug on the original as it may be a 4 speed but you only need 3 speeds. The oem motor will be more expensive then an aftermarket.
Posted on Feb 02, 2009
  • 13 Answers
SOURCE: Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
With power off, locate fan motor capacitor (generally silver in colour).
Rating on capacitor will be in microfarads at specified voltage ( 5mf @
370 volts). Be careful to discharge before handling and return defective
cap. to source of replacement. They can confirm whether or not truely
defective. Replace and secure. Restore power and check operation.
Purpose of run capacitor is to provide starting torque that you are
presently providing by hand spinning. Hope this helps.
Posted on Aug 05, 2009
  • 232 Answers
SOURCE: carrier 38ckc blower motor making a screaching
no its a sealed bearing motor, it will need to be replaced
Posted on Oct 10, 2009
ltldab
  • 152 Answers
SOURCE: How to oil a GE 5KCP39LG blower motor
CHECK OVER BEARINGS AT ENDS SHOULD BE A SMALL TUBE LEADING DOWN WITH EITHER A CAP OR PLASTIC PLUG IN OR OVER TUBE
Posted on Feb 26, 2010
TheMobilian
  • 8220 Answers
SOURCE: HVAC Blower Motor Replacement
Ain't nothing to it. Slide out the blower and take it outside. Use some rust buster to get the blower out. Don't beat on the shaft. Spread that shaft and the wheel won't come off. Use a rubber mallet. Most generic blowers have white as a common wire and the speeds are black-hi blue med and red, for low. 2 brown wires will go to the capacitor. other wires will reverse direction. Wash the housing and blower wheel good. any wire unused will be taped off to themselves. Nothing to it.
Posted on Mar 11, 2010
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
Fix problem on carrier furnace heating blower relay click sparks click again got used mother board does same. Did I just get another bad relay or something else doing it?
It is more likely the motor or the fan causing the problem at this point [or you got a bad used board].
First with the power off try rotating the fan by hand to make sure it turns freely. If it turns hard or is stuck you know the cause. If it has places to oil the bearings, add a couple drops to both ends of the blower shaft and the motor shaft and try spinning again by hand. It could be the blower relay contacts are burned and making bad contact or possibly the motor capacitor or start windings are bad. Without a model number, I can't tell what controls your unit uses. At least Carrier is one of the better companies in providing manuals and wiring diagrams.
Carrier Literature Wiring Diagrams
If you are electrically handy, you might try energizing the motor relay without the control board connected, there should be a wiring diagram on the inside of one of the panels.
Jan 28, 2015 | Carrier Heating & Cooling
Our house is hot! The ac unit outside comes on and freezes up, and the blower is not coming on. We have had the inside thermostat changed and freon added and now a new capasitor but no luck.....HLEp
Man, it sounds like you have a heat pump with a bad defrost board or reversing valve. I assume your description of the unit outside freezing up is the condenser and the blower you refer to is the condenser fan motor. Or, is it the big copper line to the compressor that is freezing up? If so, have someone stand by the inside blower and listen for a click as you move the thermostat fan switch from auto to on a couple of times., Make sure at the time you are testing that the thermostat is in the off position. Those 2 switches operate separately. If you hear those clicks during the test you probably have a bad blower motor if there are are no clicks you may have a bad blower relay or board. Hope this helps good luck.
Aug 17, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a carrier furnace and when my main blower starts up there is a short vibration just when the blower starts though and it doesn't seem to be getting any worse. the flame fires up ok and there doesn't...
I would remove both burner and blower compartment covers and reach into the blower housing and grip the center section of blower where it mounts to motor shaft. Try sliding the squirrel cage back and forth horzontally. If it slids much more than 1/8 inch then the motor bearing are probably just getting worn and allowing the motor tomake some extra noise when motor starts. If it has oil ports I would remove plugs and use 3-4 drops of machine oil and clean blower with brush and shop vac.
Other then that I don't think I'd worry much about it yet. Thank you and hope that helps.
Dec 13, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Replaced the blower motor on a Carrier a/c unit x421892 after motor seized and tripped breaker. New motor runs fine but runs continuosly when put in the auto position. The motor still runs even when...
Hello The new motor sounds HOT wired.It must have one leg connected to the blower relay.If it is off the relay(correctly) ,the relay is stuck/welded and should be replaced.In the blower unit.
Sep 17, 2010 | Carrier 38CKC036 Air Conditioner
I have a Carrier Weathermaker 8000 VS furnace that intermittently has frozen up (the inducer blower stops spinning). Do I need to replace the blower or is there something else that can be done? What is the...
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
Jan 18, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My oil is leaking, today my coolant just went too low and my heater doesnt work plus my fan blower donly works on high. help!
You have several problems. Replace he coolant you lost, but look for the leak. Likewise, determine the source of the oil leak and replace the appropriate gasket/seal.
To troubleshoot the blower, you will need a voltmeter and a schematic. Measure the voltage to the blower motor with the switch in multiple positions. This will help you determine if you need a new blower switch or blower motor.
Nov 02, 2009 | 1999 Dodge Intrepid
Heating & Cooling Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
