Question about Soleus HGW-308 Mid-Size Heater
No heat generated by Soleus HGW-308 Mid-Size Heater
My wife has been using a Soleus HGW-308 I purchased for her every day for ~1 month. As she ususally does, she had had it on in the morning, then turned it off to go have lunch. When she came back and turned it back on (after ~1 hr), it would not generate any heat. The power button indicates that power is still getting to the unit. When I turn the nob to adjust the heat, I can hear it clicking on or off, so the thermostat seems to be working, so might it be a short to or in the heating element(s) itself?
How can I troubleshoot this further? I have basic skills soldering, so may be able to do simply repairs if I can find the problem.
My cold wife and I thank you!
Bill
  • wesamuels Jan 19, 2009
    Wonderful! Thank you very much!
    I'll isolate the problem, and simply replace the part (or unit if that's what it turns out to be).
    President:
  • 1,214 Answers
If you can hear a "click" when you turn the temperature knob, and the unit is plugged in, chances are the heating has failed.
If you have a multimeter, unplug the unit from the wall.
Put the meter on R x 1000 ohms, and put the meter probes on each of the plug blades. Rotate the temperature control through it's range. You should have just a few ohms when the control has clicked (you really don't care at this point), as you turn the temperature control to a hotter temperature. You should have no ohms when turning the other way (this all assumes you are in a typical room temperature environment.).
If no reading is obtained, either the element has failed, the temperature control has failed, the "tip-over" switch has failed, there is a burned terminal in the wiring, or sometimes a heat fuse fails.
If it's the element or temperature control, it's probably best just to buy a new heater. The other three are identify and replace.
Posted on Jan 19, 2009
How do i fix my Rheem 30 gal model 71 308 from leaking?
BEWARE!!!! LEAKAGE IN WATER HEATER MAY BE EXTREMELY HAZARD DELIVERING!! STOP USING IT AND TURN IT OFF FROM MAINS, CALL AUTHORIZED SERVICE CENTER IMMEDIATELY AND DON'T USE IT BEFORE THAT!!!!
Apr 26, 2014 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Vanguard wall heater pilot will light but when to turn on heat it goes out. Thermocoupler??
This is a very good possibility and depending upon the year they may call this part a flame generator. So ask for both when purchasing. Before you run out and purchase this take five minutes and try this, I use steel wool or light grit sand paper and clean up the bulb end of the thermocouple then place it top center of the flame as this is the hottest area of the flame, now with a small wrench check to see that it is tight in the gas valve. Now try lighting the pilot and then the furnace. Some times a simple cleaning and tightening can cure this problem. If not now you can go and purchase a new one.
Dec 27, 2010 | Vanguard International Infra Red - Medium...
No heat or fan operation
24/7 Appliance Repair @ (608)214-5632 we are located in southern wisconsin, Thank You
May 26, 2009 | Marvin 3150 Mid-Size Heater
Back up electric heater required.
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Jan 13, 2009 | Soleus HGW-203 Micathermic Infra-Red...
Heat does not come on Coleman furnace
See if your hot surface ignitor is glowing when you first fire up.
This is the most common cause of the unit not working
Nov 30, 2008 | Soleus HGW-308 Mid-Size Heater
E3 Error Code
contact the manufacturer's website and ask /check with customer support or tech support . should be under warranty
Dec 01, 2017 | Soleus Heating & Cooling
Soleus HGW-308 Mid-Size Heater Logo
370 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
