posted by FURQAN on Jun 27, 2007
hi there ,
i cant just power on my server .when i click the power button fan moves for a second and then back off.what will be the problem i think its the problem for powersupply please suggest me in this problem.
powersupply problem or any other
Best Solution
posted on Jun 28, 2007
The power supply is your likely culprit. You probably have a bad diode in the power supply. Even if you check the voltages and everything checks out, it still could be bad because voltage checks are done with no load on the power supply. When a diode is bad, a load on the power supply can cause shut down (had the same thing happen to my pc 2 mos ago.) Try a different supply of at least the same wattage rating. If you are still having the same problem, you could be looking at a bad system board.
Hope this helps. Good luck.
Comment by nerdzilla, posted on Jul 01, 2007
Ok. So you say my solution was not helpful. Have you found out what the real problem is? If so, please post it. I would like to see what it was.
Rating Locked! (?) FURQAN has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for IBM xSeries 346 Server
Email this problem
Email this problem
Can you Help with these Servers problems?
Repair Service
Find Server Repairman Near You:
