Question about Roper REX4634KQ Electric Dryer
How to replace dryer belt on roper dryer model rex4635eq2
How do i arrange belt on pully
SOURCE: Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Posted on Jul 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: how to replace dryer belt
Remove the filter from the top>
Remove the 2 phillips screws from the top (filter housing)
Use a putty knife to pop the top by compressing the clips
on either side of the top between the front and top.
NOTE: Once the top is up remove the screws inside
to get the front off and LIFT the front up
before pulling towards you so the bottom clips
won't break.Get the lid switch disconnected and set the front aside.
Oil the rollers and idler, vacuum out the lint.
The new belt goes rib side down on the tub. The idler mounts like the one pictured
on bottom right of these dryer belt routing pics:
Posted on Dec 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Posted on Feb 12, 2009
  • 64 Answers
SOURCE: how do I get at the belt on a Roper Drter?
YOU HAVE TO TAKE THE FRONT OFF TO GET TO THE BELT. TO DO THAT YOU HAVE TO POP THE TOP UP , THEN YOU CAN GET TO THE SCREWS TO TAKE OFF THE FRONT
Posted on Sep 14, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Posted on Oct 06, 2009
I have a roper dryer but don't know what year it was made. the model number is REX4635EQ2 the Ser. number is MK0775343. What year model is this?
The second digit/character (K) indicates the year and the 2-digit numbers (07) immediately next to it indicates the week the dryer was made. The year code K is 2000 and your dryer was made on the 7th week of the year 2000 or February 2000. Click on the link below for the table of year codes of Whirlpool and Whirlpool-made appliances.
Determining the Age of Whirlpool and Whirlpool-made Appliances
Mar 30, 2011 | Dryers
Rex4635eq2 electric dryer. all switches and fuses check out. Nothing comes on and the timer doesnt move or make a clicking noise when i push the start button. what do you think? Timer? Gary
You need to check your door switch and thermal fuse. The thermal fuse is located behind the back panel at about 6 oclock. If the thermal fuse is bad, you need to make sure the vent is clean.
Mar 26, 2011 | Roper REX4634KQ Electric Dryer
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Dryer wont start, I checked the breaker I am getting power to it, just wont start, I appreciate your help. Thanks! and the Model number is REX4635EQ2
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 23, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer won't heat up. Model REX4635EQ2. how do you change the heating elements?
Before you start diagnosing your problem, ascertain that you have made a proper and positive heat selection on the control panel, then proceed.
Below is a link courtesy of www.repairclinic.com, which shows disassembly/diagnostic procedures.
http://www.repairclinic.com/Dryer-Electric-Whirlpool-Style-Version-2-Appliance-Diagram
A volt-ohm meter (VOM) will be helpful in diagnosing most issues.
http://www.ehow.com/how_2076998_use-voltohm-meter-safely.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
Purchase a VOM
http://www.omega.com/ppt/pptsc.asp?ref=HHMA&Nav=vhtj06
Below are the next 4 common failure modes to check.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If all the above checks allright, then proceed to the next steps below.
Thermal overload/cutoff thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%
3d%3di2651&PartID=2651
Cycling thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2893&PartID=2893
Motor Centrifugal Switch.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2584&PartID=2584
Heating Element Connection Wire.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di3140&PartID=3140
Timer.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di548371&PartID=548371
Sep 21, 2009 | Dryers
I have a Roper dryer and it just turns off we can
first thing to do is to find out whats wrong with the cord, get to the part of the cord that goes into the machine, wires are loose. a 220volt dryer will not heat if one of the wires are loose. you need to get into machine and make sure wires are tight. this is also a safety hazzard, do not leave machine plugged in until problem is solved
Sep 02, 2009 | Roper REX4634KQ Electric Dryer
The belt broke drum won't turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Can't get Dryer Belt on Kenmore Dryer
Not sure if your dryer is the same, but here's a diagram that may help.
Dec 12, 2008 | Roper RAS6233KQ Top Load Washer
Roper REX4634KQ Electric Dryer Logo
23 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
