Question about Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N PCU issues
I work for a school district that has several Ricoh Aficio CL3500N printers. The printers do good when they work, but they go through PCU's like no other printer I have ever seen. I have talked to Ricoh Tech Support and had help on a couple of different issues, but no help as to why these machines keep going through PCU's... Black and Color PCU's having to be replaced or start showing lines within a month or two of being changed. I have looked around for a reason why these printers just don't hold up. I have cleaned and worked on them repeatedly, but the only thing that seems to work is replacing the PCU. I am looking for any suggestions or help for the Ricoh Aficio CL3500N besides chunking them all out the door.
  • dbellanti2 Jan 28, 2009
    I have 2 Ricoh CL3500N printers. One goes through PCU's a quarter of its expected life and the other does not. A faded patch runs down my page about 1.5 inches from the left margin. The only thing to make the faded area go away is replacing the black PCU. Within a month the faded area comes back in the same location. I too have tried cleaning the inside area. I have also had a printer repair company look at the issue but they were not able to resolve.
  • Anonymous Apr 06, 2009
    I have several of these Ricoh CL3500's and yes, they EAT Photo Conductor Units! (PCU). There will always be some spot where the print will get light straight down the page in one color or another. The expected life of the PCU is 15,000 pages but I never seem to get to 7,500 without replacing the PCU for this reason. There has to be a way to repair or clean one of these PCU's to get to the stated life expectancy (+/- 15%). I have several old parts, I will look into it and post back here.
  • 58 Answers
These machines were actually made by Panasonic and they eat PCU's there is no rhyme or reason, they just do. I would replace all of them as soon as possible. These printers were pretty much interim technology for Ricoh until they developed thier own engine. I highly recommend the new 400 color series, low cost per page, vg color and consumables last a long time!
www.mfpsolutions.blogspot.com
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
HOW DO YOU RESET THE PCU ON RICOH CL3500N
I had the same issue with my CL3500N. I kept taking out and reinserting the color PCU with the same resulting error. However, I fixed my problem. My color PCU is now reset and printing
Instructions on how I fixed the issue:
1) Turn off the printer and remove the color PCU from the printer
2) Look inside the printer where you removed the color PCU and you will notice three attach points (gears) that each of the three color PCU rollers connect to the printer.
3) Notice that each roller inside the printer has an arrow stamped in metal pointing toward it. On my printer, one at approximately the 2 o'clock position, 9 o'clock position and 3 o'clock position.
4) On the color PCU look at the end of unit that you insert into the printer. Notice the white female connectors on each of three rollers. Look closely and you will see that there are notches inside each connector (gears). One of those notches is longer than the others.
5) For each roller insert your finger into the white connector (gear) to rotate the roller so the long notch aligns with the arrow inside the printer. Be careful not to touch the photo sensitive area of the roller.
6) Insert the color PCU into the printer and turn it on. May need trial and error to align the notch correctly, but it certainly worked for me.
Oct 06, 2011 | Ricoh Aficio CL3500N Laser Printer
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
On a ricoh aficio 3500n color laser printer getting a replace black cpu error after changing the black cartridge. How do i take care of this?
replace the black pcu(drum unit).
the life of the pcu(s) are 15k each(blk & col) .
the machine will work but copy quality will reduce and the error will be there.
replacing the cartridge has nothing to do with this error.
Jan 14, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio c3500 printing red lines accross the bottom of the page. This is an intermittent problem. Any ideas? Thanks.
If the lines are red the problem is with the transfer bel t/ cleaning unit.
If the lines are magennta( pink) problem is most likley the color pcu unit
or transfer unit
Good luck
;;Drew
Jan 04, 2010 | Ricoh Aficio CL3500N Laser Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh cl3500N printing with blank streaks in middle of page and faded quality black printing and black ink blotches on sides
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Jun 28, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
May 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
1,255 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
