Question about Sony TA-FE370 2-Channel Amplifier
Sony TA-FE370 2-Channel Amplifier - Sony TA-FE370 2-Channel Amplifier
paulm10
  • 73 Answers
SOURCE: AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Posted on Jul 09, 2009
  • 17 Answers
SOURCE: How to refurbish an old Sony TA-FA 5 ES amplifier?
If you have sufficient knowledge, you should start by replacing all the electrolytic capacitors.
Posted on May 19, 2010
  • 99 Answers
SOURCE: Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
Posted on Jul 02, 2010
caroldon
  • 17129 Answers
SOURCE: With my amplifier sony TA V902 I don't have sound
when you amplifier is powered on if the speakers are powered on and you hear that the output is switch on then it is possible that the fault of the amplifier is in the preamplifier.Open the set and check on the input of the amplifier with a signal . If there is output the fact is confirmed of the preamp stage. Now we have to confirm if the fault is in the source swtiching or the preamp equaliser/ tone section. Using a good signal tester and hoping that you are familiar to handle the electronics inside, the IC can be identified and changed. Use extreme care and test at low output, Use a help of an expert to signal trace the fault. Hope I could help. Good day
Posted on Jul 24, 2010
Kensolutions
  • 455 Answers
SOURCE: TA-1080 Sony integrated stereo amplifier suffers
I'm sorry to know that the left channel of the amplifier is not working as expected. I'll be glad to assist you with this. Please try the following steps to get the issue resolved.
If you are not able to get any sound when playing audio from one of the speaker, there may be a problem with your hookup or there may be an incorrect setting. Follow these steps to try to resolve this issue:
Try selecting a different sound mode on the A/V receiver, such as the Dolby Pro Logic II (DPLII).
A majority of cable and satellite TV channels are broadcast using two-channel analog audio. When watching one of these TV channels, only the front speakers will output audio. In order to hear audio from all speakers, make sure to change the sound field to DPLII. This creates a simulation of 5.1 digital audio. If the channel is broadcast in digital 5.1 audio, change the sound field back to AFD Auto to enjoy the digital surround sound audio as it was actually recorded.
If you still have the same problem after changing the sound mode, make sure the speakers are securely and properly connected to the A/V stereo receiver.
If your A/V receiver has an Auto Calibration function, try using it to setup the appropriate sound settings.
Perform a Test Tone operation to verify that all speakers are working.
Increase the volume level of the speakers.
If applicable, try selecting a different size (small or large) speaker.
Try these settings which should resolve the issue. Please feel free to get back to us for further assistance.
Thank you for using FixYa.
Posted on Jun 26, 2011
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
I accidentally plugged my 110V amplifier to 220V outlet.It has no power anymore.what possible solution for this. Thank you very much. Do I need to replace the rectifier in it's circuit?
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
Jul 13, 2010 | Sony TA-N9000ES 5-Channel Amplifier
Hi there.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
hope this helps.
Jul 26, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony STR-K1600
http://esupport.sony.com/US/perl/model-find.pl?mdl=TA-N1
Jul 25, 2008 | Sony TA-N1 2-Channel Amplifier
Sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
Oct 08, 2007 | Audio Players & Recorders
Sony TA-FE370 2-Channel Amplifier Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
