Question about Nikon FG 35mm SLR Camera
Nikon fg light meter
Since no light meter, shutter operates only at M90, or will open at 1/60 but not close again until moved to M90.
5 Suggested Answers
SOURCE: nikon fg light meter
Ah, I figured this out. It's not the battery, since the light isn't dimmed. I had the same problem with the light being stuck at 60/120, and it was just flashing. There's a certain mechanism in the camera that only allows the light meter to start working when the exposure count is at 1. So when you load your film, you have to take 2 or 3 exposures, and crank it, before the light meter kicks in.
Posted on Apr 03, 2010
Obertelli
  • 3006 Answers
SOURCE: Nikon FG Shutter and light meter not working
Sorry, but there is nothing else you can do without dismantling the camera and giving it a full service. It's not a DIY job so will have to go to a repair specialist.
Note that unlike some similar Nikon models of the time, the FG's complex electronics mean that your camera may now only be good for spare parts as it's likely that the main circuit board has failed and replacements simply are not available and arevery difficult and expensive to fit if you're lucky enough to locate one. The reputation for failure of this model due to ageing circuitry means that it's now unpopular and near worthless.
A repair specialist can certainly tell you whether the camera is repairable before undertaking any serious work on it.
Personally, I'd just advise you to sell it as is for spares or repairs and to obtain a working example or even the mechanical Nikon FM/FM2 which are still plentiful, easily serviced and repaired, and available fairly cheaply or even free (via FreeCycle).
Posted on Apr 08, 2010
Testimonial: "Thanks Obertelli for taking the time for the detailed answer. I am hoping to keep the 50mm lens and hopefully use it with adapter."
SOURCE: My Nikon FG's light meter
Try new batteries, And make sure the frame counter is past one to get meter to work right.
Posted on Nov 13, 2010
inlarry4
  • 98 Answers
SOURCE: Nikon FG. Replaced 3V
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Posted on Sep 04, 2011
Nikon fg light meter not working
Light meter only works with the back door shut and the film counter is at frame 1 or more !!, Also if the camera is set at M90 or bulb (B) mode, Meter will not work there ether,
Nov 13, 2013 | Nikon FG 35mm SLR Camera
Nikon FG Shutter Speed Fixed at 1/90
needs repairing at a qualified shop, if you thnk its worth it
Apr 23, 2012 | Nikon FG 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
Jun 29, 2011 | Nikon FG 35mm SLR Camera
The shutter will only close in the B or M90 postion. It opens fine, but won't close. What should I do?
Try a new set of batteries. The shutter is electronically operated at all speeds except the B and M90 settings. If the exposure meter works with a new set of batteries but the shutter still does not, then you'll have to take it in for service.
Feb 20, 2011 | Nikon FE 35mm SLR Camera
I followed the instructions in the manual, and put new batteries in + side up. Then I continued with the rest of that step, but I did not see a flashing red LED light anywhere. I do not understand what to...
A few things to try, based on my FG's operation: - The most obvious- are your batteries good? Correct type? If they are: - When all is well the red LED metering lights will appear in the viewfinder window on the right side, in the range of shutter speed numbers. - The red LED metering lights are only activated when you press the shutter release button (halfway). The lights go out after a few seconds if the shutter button is not held down. Just tap the shutter button to reactivate them. - The shutter speed setting dial must NOT be on B (Bulb) or M90 (non-electronic Manual mode) if you want to see the red LED metering lights. The lights do not operate on these two settings because metering is irrelevant here (you'd be doing the metering, not the camera). - If you're in P (Program mode) the lens aperture must be set all the way to the smallest setting (usually f22 or f16, depending on the lens). If not, you'll only see blinking lights at the top and bottom of the shutter speed range on the right in the viewfinder. That's a reminder to set the lens to the smallest (highest numeric) aperture.
Hope these help. The FG is a great little camera.
Aug 14, 2009 | Nikon FG 35mm SLR Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Nikon FG 35mm
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
http://www.cameramanuals.org/nikon_pdf/nikon_fg.pdf
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Shutter staying open and only closing when dial moved to M90 or B
It sounds like your cameras need a CLA (clean, lube and adjustment). Occasionally when this has happened to me, i noticed that it was the foam on the mirror bumper that had gotten all deteriorated and gummy and as such the mirror would 'stick' to it when it flipped up. Changing the foam seals might do the trick.
Switching to M90 means that the camera is in Manual mode whereby it is not relying on the electronics at all in the camera. When your battery dies in mid shoot, you switch to M90 and you shoot manually at a fixed speed of 1/90 second. Of course your light meter won't have power, but if you meter manually or go by the 'Sunny 16' rule, you can adjust the aperture and get your shots.
Yes, moving the shutter dial to M90 should release the mirror back down, if it is stuck up.I'm assuming of course that you didn't manually set the mirror up anyway... Test it out with brand new batteries!
Nov 20, 2008 | Photography
Nikon FE
TRy firing the camera in the M90 setting. If it fires properly, use the battery test switch. If the battery LED doesn't light up, replace the batteries (2 MS76 type). The FE requires healthy batteries to operate the shutter. If the meter is calling for a slow shutter speed (low light or lens cap still on?). If the batteries are good, but the shutter still won't fire normally in sufficient light, looks like you're in for a repair shop visit.
Feb 11, 2008 | Nikon FE 35mm SLR Camera
Shutter jammed
Did you set the camera to M90 AFTER you installed new batteries? The camera will work without batteries in the B and M90 settings, but when you install new batteries, reset the mirror by turning the dial to M90. If this doesn't correct it, I wouldn't recommend opening the camera - take it to a repair shop.
Nov 23, 2006 | Nikon FG 35mm SLR Camera
Nikon FG 35mm SLR Camera Logo
89 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
