Question about Watches
Analog time does not match digital time on a model 5255 GA-150A g-shcok
SOURCE: Time's do not match
if you still need to do this email me on kfsmail@aol.com
Posted on Jun 24, 2007
escapement
  • 2334 Answers
SOURCE: gettting the analog and didgital times to sync on my watch
Find Citizen manuals in my tips.
Posted on Jan 28, 2010
escapement
  • 2334 Answers
SOURCE: Time in the small digital window and the analog
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please.
Posted on Mar 15, 2010
  • 2501 Answers
SOURCE: tissot touch watch, the digital time is correct, the analog not.
You can get a set of instructions from their web site (tissot.com).
At the bottom of the page there is a menu; select "warranty" and a number of alternative PDF files appear on the left.
If you can't see what you want, select "user manual" from the menu at the top and enter the details of your watch.
Choose the one that is suitable for your watch and download
Posted on Mar 21, 2010
Testimonial: "this is the conclusion that i also came up with."
mark_vici
  • 58 Answers
SOURCE: Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Posted on May 03, 2010
Need a Casio G-Shock Users Manual for GA-110
COPY AND PASTE THIS LINK INTO YOUR SEARCH BAR AND YOU SHOULD SEE THE USER MANUAL.
http://mygshock.com/casio-manual/5146/
Mar 28, 2016 | Casio G-Shock World Time Analog Digital...
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
Cant get analog to sync with digital time. I live in SC and I try to set the time for 22:36 but then the analog set it to 12:36 am. :/
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
May 08, 2013 | Casio G-Shock GA-110-1B GA-110-1 Mens...
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
How do i set the anolog time
Go to "setup" pushing mode sometimes then right down push should move analog clock
May 20, 2012 | Casio G-Shock World Time Analog Digital...
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Watches Logo
26 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
