Question about Roper Dryers
How to replace belt on roper rab4232ew1
I opened it up because it filled up but won't wash. I see a belt but don't see where it should go..???
Dissolu
  • 221 Answers
SOURCE: roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
Posted on Jul 25, 2009
  • 24 Answers
SOURCE: brand new roper washing machine model # RTW4440VQ2...
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
Posted on May 26, 2010
  • 403 Answers
SOURCE: Kenmore Dishwasher - fills with
Sounds like a problem with the main motor.
Posted on Jul 09, 2011
  • 160 Answers
SOURCE: water fills in, but wash cycle won't
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Posted on Jul 28, 2011
  • 884 Answers
SOURCE: hi my hoover nextra HNL 6166 washing machine won't spin
Have you renewed the motor brushes?
Posted on Apr 22, 2012
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
When washer fills for wash or rinse it won't stop filling and over flows onto the floor.What do you think it is ?Is it a float problem?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Roper RAX4232KQ Top Load Washer
Roper model RAB4232EW1 doesn't spin out most of the water on close. Spins and drains but leaves close too wet.
Pulloff the back of your washer sounds like you might have overloaded it and cause the belt to slip. Should be just a couple of screws when you look in with a flashlight you should see the issue if you dont start it up on a dry run and watch what happens. But I am guessing that the belt must be slipping. Let me know what you find and I hope it helps!
Dec 22, 2010 | Roper Washing Machines
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
Stopped Dead
these machines only have 2 problems
dive coupling no wash or spin
or lid switch machine totallaly dead normally caueded by droping heavily & breaking the housing of the lid switch
Oct 30, 2008 | Washing Machines
Dropped foreign object into corner opening
no you can lean the machine backwards and should be able to remove it with out any disasembling of the unit, if it did not fall all the way to the bottom and you can not remove it it will not hurt anything
Apr 16, 2008 | Roper RAB5232E
Dryers Logo
22 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
