Question about Linksys Wireless-G WRT54G Router
Linksys Power cut problem
Hi, we have a standard broadband, standard laptop and a Linsys wireless router, everything works fine until a power cut or my 17 month old switches the swich off (that the router is plugged into) then we cannot connect to the internet.
We have to set up the whole system again which takes us a good hr or so... This only happened AGAIN last week when my little girl turned off the router at the plug. I managed to fix it, (don't know how buttook ages) then tonight we get a split second power cut and it's gone again!! It is really annoying.
We have downloaded Linksys Easylink advisor to help. We can connect to the internet when wired, and our wireless says it is still connected with excellent signal etc etc, HOWEVER take out the cable to use the wireless and it displays the usual 'this page cannot be displayed please check your connections'.
Last time I got it working I used the Easylink and it goes through the processes of setting up a new router (whilst wired at this point) It says cannot find an active internet connection, whilst I have google running in the background running ok???
I press next and it asks for the usual wireless name etc and searches for another connection and says still can't find it, I thought I can't be bothered anymore and closed it down and unplugged the cables and found the internet all of a sudden still running ok... Great fixed but don't ask me how I did it... so tonight after our tiny power cut, went through the exact same motions again and nothing! So the only connection I can get is through wired or someone elses non secured wireless. Can someone please help us... we have had this problem and fear of anymore power cuts. Many Thanks
  • seanandcarin Jan 19, 2009
    Where do I get one of these UPS and how mucg do they cost?
    Thanks for the speedy reply
    Hi, sorry it doesn't recognise the 192 address.
    Genius:
  • 1,268 Answers
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Posted on Jan 19, 2009
How do i find the code for linksys wireless g broadband router
steve130823
The link below will help you look up the wireless WEP key on your router. Note most of the interface screens on all the Linsys models.
http://www.fixya.com/support/r6043023-setup_wep_wireless_g_broadband_router
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 13, 2010 | Linksys Wireless-G Broadband Router
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
I have a wt54-g broadband router. when trying to go wirless everything went through fine except 1 problem it says cannot connect to the internet. Any way to solve this?
Unplug house connection or router for 30 seconds, then do the linsys for 10 seconds and plug back in. This should reset everything to work correctly. If needed, reset ip address on your pc. Set up home network if necessary.
Sep 12, 2009 | Linksys Wireless-G Broadband Router
My linsys wireless g broadband router appears to
Check your power adapter with a digital multimeter. Make sure the voltage is no higher than .5 volts than what's listed. If the voltage is malfunctioning and it gets to high, it can damage the ethernet port and more on your system if it is connected wired.
Aug 09, 2009 | Linksys Wireless-G Broadband Router
Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
May 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless G Broadband 2.4G Router
Try to reset the router for 20 seconds. There's a reset button at the back of the router. Just press and hold it down for 20 seconds, then unplug the power for 30 seconds, the plug it back in. Now try to reconnect to the Linksys wireless network.
Aug 21, 2008 | Linksys Wireless-G Broadband Router
Laptop cannot connect to router
also make sure that the firmware is updated for the router. go to the linksys site, find your model and download latest firmware.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
210 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
