Question about Ubi Soft Entertainment Monster 4x4: World Circuit for Nintendo Wii
Steering on monster 4x4 world circuit
WE can not figure out how to steer the wheel on the game. Every time we hit the 2 button and try to turn the wheel it just turns in circles it does not matter which direction we turn the wheel. Can someone please tell me how to steer this. My son wants to play but no fun going in circles, it won't let him play anything else until he gets the steering down.
  • 30 Answers
The controls are VERY sensitive for this game.
But for the "circual driveng no matter what" is more like a problem with the wheel itself rather than the game.
I suggest returning the wheel and buying a new one or simply not using it and playing with just the Wii-mote itself.
I hope this helps!
Posted on Jan 20, 2009
The horn blows some times when the steering wheel is turned
You might need to disassemble the steering wheel to access the horn button / switch there' could be something loose in there which is causing a closed circuit when the steering wheel is turned. May be solved by tightening or the horn button / switch may need replacing.
Mar 01, 2011 | 2006 Hyundai Tucson
My traxxas 3.3 monster steering is twitchy but is working in reverse. ie turn steering left , wheels turn right and vice a versa. Have not touched steering linkage at all
I hate to say this but... the reversed steering problem could be in the remote or in the chassis. Reversing the 2 wires on the steering servo would most likely the quickest fix. However.... what you really have is a product defect.
If you have a receipt I would recommend exchanging it at the retailer or go through the nightmare of a product warranty before doing any repairs.
Traxxas offers a 30-day limited warranty on all their electronic components and a two-year, manufacturer-defect warranty. You have a manufacturers defect.
http://www.traxxas.com/support/Traxxas-Warranty-Service
1-888-872-9927
I hope this points you in the right direction. I personally would not mess with an under warranty unit. It would void the warranty.
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 25, 2010 | Traxxas T Maxx 3.3 Monster Truck
Horn does not work on a 1993 cutlass ciera
Try to find the horn and use a test light to try to ground out one or the other contacts. The horn should be energized at all times, as long as the battery is charged.
The horn should sound if you ground out one or the other terminal with a test light. If not, then the horn is bad.
Also, one can check the button at the steering wheel. If one uses a test light to ground out the switch there, the horn should sound.
See fig. 3 for wire for horn in steering wheel:
REMOVAL & INSTALLATION
Without Air Bag
See Figures 1, 2, 3, 4, 5, 6, 7 and 8
Disconnect the battery ground cable before removing the steering wheel. When installing a steering wheel, always make sure that the turn signal lever is in the neutral position.
  1. Disconnect the negative battery cable.
  2. If your vehicle is equipped with controls for the radio on the steering wheel proceed as follows:
Fig. Fig. 1: Pry out the control button assembly with a thin-bladed tool along the top of the edge, being careful not to damage the control assembly
  1. Pry out the control button assembly with a thin bladed tool along the top of the edge of the assembly.
  2. Disconnect the steering wheel control.
  1. On vehicles without the radio controls on the steering pad, take a thin-bladed tool and pry the pad off the steering wheel. On wheels with a center cap, pull off the cap.
Fig. Fig. 2: Common steering wheel pad types
  1. After lifting the trim off, pry the horn wires from the back of the pad. On some models gently push down on the horn lead and turn left, the wire and spring will then come out of the canceling cam tower.
Fig. Fig. 3: Carefully pry the lead wire for the horn off of the horn pad
  1. Remove the retainer ring with a pair of ring expanders, then remove the steering wheel nut.
Nov 19, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
How do I add players/ controlers to wii 4x4 circuit?
press the button on the wii remote with a picture of a home and then press remote settings and then press reconnect and then press 1 and 2 alternatly on the remotes u want to connect
Mar 30, 2010 | Ubi Soft Entertainment Monster 4x4: World...
Pulling steering wheel
1 disconnect the negative battery cable
2 remove air bag module/ horn button
3 remove steering wheel retaining nut
4 use steering wheel puller to remove steering wheel
Mar 15, 2010 | 1999 Chevrolet K2500
My 2005 chevy silverado 1500 hd 4x4. I am experiencing a slight but annoying wobble in the front end at slow speed. The steering wheel is rock steady but the shaking can be felt through the steering wheel....
Chevy is having problems with the steering columns on these models. Feels like a jiggle in the steering wheel when you hit a bump of any kind. Cost about $75 at the dealer for a new part.
Mar 01, 2010 | 2005 Chevrolet Silverado 1500HD
Steering on a remote controled car not working
Check the servo saver to make sure it is not loose. You should be able to hear the servo move or try to move. If it does not make any noise when you turn the wheel on the controller open the receiver box and make sure that the steering servo has not come unplugged from the receiver. If these things check out the servo could possibly be bad. They can get damaged if they get wet or are hit hard enough.
Dec 06, 2009 | Traxxas E-Maxx 4WD Monster Truck RTR
Steering wheel won't lock - neither will the doors
sounds as if the locking mechanism is wearing out or not making the proper connection to the steering wheel
Jun 30, 2009 | 2006 Volvo S60
Logitech force steering wheel problem
I hooked the wrong power supply to my wheel.Pretty dumb I know.Is there a protection diode or something I can replace or do I have to figure this out on my own?
Jim
Mar 19, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Ubi Soft Entertainment Monster 4x4: World Circuit for Nintendo Wii Logo
91 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Adam Jasar
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
