Question about HP PSC 1610 All-In-One InkJet Printer
Printer is telling me that the ink cartridge is not compable
Have not changed cartridges, but printer has been printing. then it stops and says it is not compable with printer.
    Problem Solver:
  • 5 Answers
I take it that you are probably either using generic or refilled cartridges. Try using a Penguin / Pelikan or an original. Should sort out your problem
Brian
Posted on Jan 20, 2009
I have an epson sx510w how to change ink cartridge
use the tool button to access the menu and let it know you want to change cartridges. IF you dont have the instructions then go here and download the basic operation guide
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX515W/Drivers-Support?defaultOSId=3&target=#
Jan 08, 2012 | Epson Office Equipment & Supplies
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Color ink cartridge
My problem is fixed. Thanks to all who shared a resolution.
Sep 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother mfc-5440cn
The cartridge has no chip to reset. I'm guessing that the problem might be the printer. Have you tried turning off the printer for about 30 seconds? If this didn't work try turning it off and unplugging the usb and power for 30 seconds. This is to reset the printer to recognize a full cartridge. If this doesn't work, did you put the cartridge in the correct position? Is it aligned correctly? Hope this helps.
Jul 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
