Question about Amana ARS2464B Side by Side Refrigerator
Water seeping around fitting on back where water line fastens tp
Seems to seep when defrost cycle starts or stops about twice a day. should I change compression fitting on copper line?
    President:
  • 1,214 Answers
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Posted on Jan 19, 2009
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Leaks onto the floor
With or without a load in the dishwasher, start the wash cycle and watch the whole thing. Inspect around the door to see if water is seeping through the seal. If no water is leaking around the door, then there may be a cracked hose line somewhere else.
Apr 12, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Water that seeps into washer after cycle is done
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Vic
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Gets stuck in defrost cycle, new thermostat already fitted
If you would like to stop the defrost timer from intermittently causing this, the defrost timer will need to be replaced. It's a simple part to replace and not expensive. Thanks, Sea Breeeze
Apr 27, 2009 | Refrigerators
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
Amana ARS2464B Side by Side Refrigerator Logo
94 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
