Question about Packard Bell Computers & Internet
Remove he dvd drive from Packard Bell computer
I want to replace my cd/dvd drive but I cannot figure out how to remove the old unit from the tower.
  • 296 Answers
Remove both left and right panals on the tower. Disconnect the IDE ribbon cable and power from back of the cd drive. There also may be a small wire that connects ether to the sound card or motherboard also. Remove all screws from the right and left side of the device. Push the drive out the front.
Posted on Jan 19, 2009
Insyde BIOS SCU 1.11 does not recognize a new DVD drive
You just need to replace your 80 pin data cable or power plug.
Good Luck
Aug 20, 2012 | Computers & Internet
Packard Bell how to take out DVD writer
usually there is a small cross headed brass screw underneath laptop case that needs to come out
turn over laptop when off
look for door to cd/dvd player
trace your finger in middle of door about 2 to 4 inches in case on bottom
should see a small screw there
will require a tiny phillips head driver to remove
then should slide out with a little push on base of drive housing
May 24, 2012 | Packard Bell Computers & Internet
Need to replace cd dvd drive on packard bell easynote tj61
There is usually one or two screws that holds the DVD driver, flip laptop over, now look at the area where the DVD is, you should see one or two screws with or without a lock symbol, remove screws and gently remove player, don't forget to open the tray easier to remove. Check ebay to see if they have what you are looking for.
Mar 06, 2012 | Packard Bell Computers & Internet
The disc tray wont close
Try removing the CD-ROM drive from Device Manager and restarting the computer so that it will find the driver again and re-install it automatically.
Otherwise I'd explore getting a new drive. They are very cheap these days.
Aug 01, 2011 | Packard Bell (ATXMH28AP) Full Tower Case
Packard Bell computer won't play dvds.
This sounds like a common problem. You need to install the drivers (small programs that instruct the computer to notice and manipulate peripherals, like a dvd or cd player, sound card, etc...).
The easiest place to find your specific driver is at the Packard Bell web site under support > Downloads. There are MANY sites (even some that advertise on this very site) that say they have the drivers for your dvd drive, but go directly to your manufacturer's web site. These companies that provide drivers for computers install a program into your computer and there is a fee for use of these web sites.
UPDATE: I just checked the Packard Bell Web Site and was unable to find specific drivers for your particular model. They stopped making them some time ago, and no longer support the model. That being said, you can still conceivably find the drivers, it will just take some investigative work on your part. In doing a broad search on the internet, I found that many people are looking for that very driver, which is an indication it has become hard to find.
Jun 15, 2009 | Packard Bell GCD-R580B (gcdr580b) Internal...
Need to remove case to change DVD writer
Check the back of the PC case, There maybe a screw that needs to be removed in order to open the side panel. Another thing could be that there is some kind of sliding lock, that is holding the panel in place. Keep playing around in the back of the case, most likely you'll find it within a few minutes.
May 27, 2009 | Packard Bell (ATXMH28AP) Full Tower Case
Packard Bell Easy note R1000 - CD/DVD Rom
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Sep 09, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Packard bell restore new Hdu
From parkard bell suppport website Quote
"Step 4 - Re-installing your software
Call the help desk and ask them to guide you through the
ExtHS process.
Please have your Recovery CDs to hand when you call
the Easy Repair line.
Once you have completed the ExtHS process you will
need to re-install Windows and the other software supplied
with your Packard Bell computer. To do this follow the
steps below:
1. Disconnect all peripheral devices (web cam, printer,
scanner, broadband modem etc.).
2. Insert the Packard Bell Master CD 1 / DVD in the top
CD / DVD drive and restart your computer.
3. The CD will load and display the following message:
Please refer to the section headed Packard Bell
Recovery Program in your user’s guide for instructions
on this utility. Press OK if you want to continue
or Cancel to return to DOS.
4. Press the letter O on your keyboard to continue.
5. You will see a menu with options. Please select option 1
“Standard System Restore”
by pressing the 1 key on
your keyboard.
6. A warning message about data loss will be displayed.
Press the letter O to continue.
7. The process will take around 40 minutes. Once this is
done you will need to restart your PC. Remove the CDs
and store them in a safe place.
8. If there was a Software Library DVD supplied with your
PC you can use this to install the extra software that was
supplied with your computer. Insert this into the drive
and follow the onscreen instructions.
9. Finally, you will need to install any additional devices
(web cam, printer, etc.) and software by following the
instructions supplied with them."
Jun 09, 2008 | Packard Bell Computers & Internet
Packard Bell IGo 4000 series Versa E400
If you cannot see the speaker icon in the taskbar, click on Start > Control Panel > Sounds and Audio Devices and tick place icon in the taskbar. That's if a driver has been installed for your sound device which is a creative sounblaster I think.
Jan 08, 2008 | NEC Versa SX Notebook
Computers & Internet Logo
458 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
