Question about Cycling
Reebok z9 excercise bike resistance gone in pedals
2 Suggested Answers
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
I have error code 02 on my reebok z9 run treadmill what does it mean
Go to www.reliable-store.com and get info on whether to repair or not, service it, and how to repair etc
Mar 09, 2018 | Reebok Exercise & Fitness
Reebok z9 treadmill beeping with error e01,this happened once before then went ok,driving me mad any help please
Try to check the Speed sensor. Check for its aliment also check is there is any dust accumulated on it .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Reebok Exercise & Fitness
My Z9 treadmill will not turn on... i've flicked on the power swtich and the switch on the machine but it wont sstill come on. what can i do?
Our Z9 has just done the same, switched on the power but it doesn't turn on. Was just wondering if you managed to fix yours and if so how?
Thanks.
Sep 12, 2013 | Reebok Exercise & Fitness
Reebok rx2.0 console stopped working
Hi I'm having same prob. Did you ever get solution
Feb 25, 2013 | Reebok Indoor Trainer RX 2.0 Upright Bike...
How do i lubicant my reebok b5.8e bike
Well I'm not familiar with Reebok exercise bikes specifically, but I am familiar with bike pedals in general. It looks like these are rather cheap plastic pedals that are sealed (no real way to take them apart and lubricate them). I suggest you try using some kind of household oil, 3 in1 etc. or maybe WD-40.and spray on the inside side of the pedal. If you take them off the machine, it might be easier to see where to spray or drop oil in the best area. If you do decide to take them off, the left hand pedal is reverse threaded (to unscrew the left pedal you must turn the axle of the pedal that unscrews clockwise to remove). The right pedal is regular thread (counter clockwise to remove). Depending on how much space is between the crank and the pedal body, you might have to get a special bicycle pedal wrench available from a good bicycle shop (Park tools are the best). The special wrench is very thin to be able to get between the crank and the pedal body which is usually very narrow between the pedal and the crank. If this doesn't work, I'm afraid you probably going to have to buy new ones in order to get rid of the squeak. If you don't mind doing away with the pedal straps, you could get cheap pedals at a bicycle shop. If you do choose to go this route take the pedal with you. There are two different pedal axle diameters: 1/2" and 9/16". The 1/2" isn't very common anymore, so it will probably be 9/16". The pedals usually marked L and R on the ends of the axel. If French it's D for right and G for left. If not, you will just have to try them to see which pedal is left and right by trying each one (remember preceding instructions). Good luck!
Aug 08, 2012 | Sport & Outdoor - Others
Can you confirm what Reebok Edge excercise bike fault code E1 what this means as I have lost manual.
Same problem here! means that the motor is not sending a signal to the computer!? But that as far as ive got....................
Jan 11, 2011 | Reebok New York Giants Eli Manning Jersey
My Reebok RB1 exercise bike is not increasing resistance and I wish to get inside to check to see if I can fix the problem but I am differculty in gettng the pedal lever off - can you help please?
Hello,you only have to take the peddles off. The right one comes of anti- clockwise, and the left one comes of clockwise. There is a large plastic ring on the cover at the place where the peddle shaft goes in. get a screwdriver into this and prise it of, this will allow enough for the cover to come of. Mines is the same not enough power to pull cable.
Sep 20, 2009 | Cycling
Exercise bike will not load
Check the manual. If you don´t have it, check here Reebok manual
Jul 16, 2009 | Reebok Exercise & Fitness
Handlebar on my reebok rb1000 exercise bike has snapped, where can i get a replacement ?
i have a reebok rb1000 exercise bike when i adjust the load up the resistance doesnt change. can anyone help
Apr 30, 2009 | Cycling
Reebok bike model no REV10201.......lost programme manual
Hi I got this Manual REV-10201 Fusion Bike.pdf sent from Reebok Tech yesterday for Free you can download it at the following link http://www.sendspace.com/file/62csf6
Mar 16, 2009 | Reebok Exercise & Fitness
Cycling Logo
80 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
