Question about Gateway 450ROG Notebook
I accidentally dropped my Gateway laptop and I guess it broke the internal part where you plug the charger into it. The computer itself works fine and the charger worked for a few days as long as you held the charger cord to the side real tight but it eventually stopped charging. Do you know the name of the part I need to replace to fix my computer?
    Sergeant:
    Champion:
  • 318 Answers
The part is called a Power Jack, or Motherboard Power Jack.
Most service centers can resolder the connections.
Posted on Jan 29, 2009
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
My Gateway NV53 has just stopped charing period. The Computer doesn't even reconginize that the charge cord is in. Can someone help?
This happened to me a couple times, the first time, I had to send my computer back to the factory because the DC board was defective but the second time I just had to leave my charger unplugged for an hour or so and then it worked fine. Sometimes, the charger will heat up to a point where it shuts itself off before it literally starts to melt.
Hope this helps, Nathan Taylor
Jul 21, 2011 | Gateway NV5378u Notebook
My computer was dropped and broke the power button along with the plastic case around it
Hi aprilbonham,
I recommend contacting your computer manufacturer and ask assistance with their technical support. Ask if they could repair the system even you accidentally dropped the computer. Most of physical damage voids out the warranty so you need to contact them to check if your system is still in warranty and can cover induced damage.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Jan 17, 2011 | Gateway NV7802U Notebook
I have a Gateway 3520 laptop and a couple months back it got dropped on it's side where the charger is plugged in. After that incidence the only way to keep it charged was to tape down the charger. That...
Replace the dc jack. google it, open the computer and replace it. It takes some soldering skills, be careful or have local tv shop solder it for you.
Jul 16, 2010 | Computers & Internet
My Gateway NV5386u battery died and the computer shutdown. When I tried plugging it in, it still would not turn on. The adapter part of the charger has a green light, indicating power is being applied, but...
Often when a battery is real flat, it hangs up the entire system. What you need to do, is remove the battery completely, as the laptop should be able to be powered by the AC adapter itself. You may find if that is the case that your battery has gone bad, and you will have to replace it. If your laptop, will NOT work from the AC adapter, then either the adapter is faulty, or there is an internal vault, in the Power conditioning circuitry inside the PC. Try another adapter, if still no go, then it is definitely an internal problem.
Jul 16, 2010 | Gateway NV5386u 156Inch Laptop (Blue) PC...
My gateway m285 doesn't always power up ....sometimes it won't ...help?
This problem usually occurs when you have dropped your computer. However It could be caused by many things. Have you checked to see if it charges correctly? Try buying a new charger, and if it does not work than just return the charger, and take it to a professional. Internal problems are very complicated and I dont reccomend you do it yourself
May 23, 2009 | Gateway M285-E Notebook
I dropped my laptop and now the battery will not charge.
Most likely its the DC Power Jack. Happened to me. You can find the part online by searching for "450ROG DC Jack" and then just resolder yourself or take it to a repair shop.
Jan 19, 2009 | Gateway 450ROG Notebook
Dropped my gateway laptop. Now it wont charge battery.
If you do not have either a manufacturer warranty or extended warranty from the retailer use it now. Contact them. Avoid telling them that you dropped the computer...you will void a manufacturer warranty. If you don't have either option then you can continue portability with an external laptop battery. They tend to be heavy, but they tend to provide 5 or more hours of portable use. The extended battery plugs into the same socket as your regular external power supply. I have included some links for product options.
http://www.youtube.com/watch?v=q1om-j6AGNg
http://reviews.cnet.com/1990-3121_7-5127099-1.html
http://www.batterygeek.net/Portable_Power_Stations_s/38.htm
http://www.amazon.com/s/ref=nb_ss_gw_0_13?url=search-alias%3Daps&field-keywords=external+laptop+battery&sprefix=external+lapt
Good luck
Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
Nov 07, 2008 | Computers & Internet
Gateway 450ROG Notebook Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
