Have grunaire mini split. U5 error code comes up and the init does not work in hearing cycle
5 Suggested Answers
  • 587 Answers
SOURCE: Need an expert on Grunaire Mini-split systems.
If you are low on refrigerant, and if you have a low pressure switch, it will not allow the compressor to come on in heat or cool, until you put a jumper across the low pressure switch or add enough refrigerant to get the pressure up to close the switch. You can only add refrigerant to a system if the bottle pressure is higher than the unit pressure without the compressor running.
Normally a technician will hook his gages up if suspects the unit is low on charge or he will push the contacts closed on the contactor and feel the suction line to see if it's cold.
Posted on Aug 07, 2009
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
  • 51 Answers
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
SOURCE: Newly installed grunaire GSI120HR Split
Have have a grunaire for over two years now, very happy with it
Posted on Nov 26, 2011
I have a grunaire split ac system. I moved in and just was given the remote. What do all the symbols mean? How do you get the ac to work?
Service Manual - Grunaire - LoPDF
www.lopdf.net/...,/Service-Manual-Grunaire.html?...Grunaire-Remote-C... 1 Summary and features Indoor Unit GSI091HXD GSI121HXD Outdoor Unit GSU091HXD GSU121HXD Remote control window YT1FF Summary and features.
hope this is your unit, on page 11 it tells you what the buttons on remote do
Mar 03, 2015 | Heating & Cooling
Error code u5
AC current detected circuit malfunction.
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
E pa au u5 5e
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
May 15, 2014 | Frigidaire Affinity FAHE4044MW 27"...
Our Xerox Phaser 4500 printer has printer cooling fan error. Call Service - Code U5
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
Feb 10, 2011 | Xerox Phaser 4500 Printer
I also have a grunaire dual zone mini-split that doesn't work worth a ****. I've had it looked at multiple times and had freon r410a added twice and still nothing. Without the high side - how do you know...
an FC fault on a Grunaire is typically a defective PFC board in the outdoor unit or a Grossly overcharged system, where the drive cannot overcome the standing pressure to start the system up...
the ONLY CORRECT way to charge one of these units is to WEIGH in the charge..
the Label on the side of the unit will give you the correct charge amount.. this is for 25 feet of Lineset on Each indoor unit... typically on a 9 or 12k btu indoor unit (1/4" liquid line) you will add 0.7 oz refrigerant extra per extra foot of lineset.....
the PFC board failure is a very common failure on all of the grunaire / chigo built units...
Jun 25, 2010 | Heating & Cooling
Compressor shutting down
FC IS FREON CHARGE, WHAT YOU ARE GETTING IS A HIGH PRESURE CUT OFF  FAILURE. THE LABEL PRESURE IS TEST PRESURE. THE RUN PRESURE ON LOW SIDE IN AC MODE IS ABOUT 65 AT 75 T0 80 DEGREES INSIDE AND ABOUT 200-300 HIGH SIDE AT 75 -85 OUTSIDE TEMP. IN HEAT THE LARGE COPPER LINE BECOMES HIGH SIDE HOT WHEN YOU FEEL IT. IF YOUR FREON IS LOW WILL WILL ALSO GET SHUTDOWN. YOU WILL NEED SET OF FREON GAGES AND CONTACT ME BACK
Apr 23, 2010 | Heating & Cooling
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Need an expert on Grunaire Mini-split systems. Need troubleshooting guidance - compressor will not run -only fan comes on. Get a ''P8'' error. I thought it was due to low refrigerant. I had to install 35...
Aug 03, 2009 | Heating & Cooling
May 07, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
