Question about Dryers
Hi WE are trying to determine if we need a new belt for our Maytag model LDE480 dryer. How can we access this?
    President:
  • 1,214 Answers
What problem are you having that makes you think it's a belt?
Belts are normally accessed from the backside of the appliance. There will be an access panel that can be removed.
Follow all labeled warnings when working on an appliance.
Posted on Jan 19, 2009
How to change drum belt on a maytag dryer
The belt changing is fairly the same across all brands and models, The issue come down to your model number and how to access the belt via panel removals. Can you provide the model number? (Hope you've repaired it by now)
Sep 26, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
My PYE/4500AYW is noisy when drum is revolving. The belt appears to be OK. I have the top panel off but how do I access the rest
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 20, 2011 | Maytag PYE2300AY Electric Dryer
Maytag Model LDE4914ACE Electric Dryer making a very loud noise - belt? some other part?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 29, 2011 | Maytag Dryers
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
There is intermittent squeeking when the dryer is in operation. Is this the drum bearing or the drive belt? How do I access both to check?
heatman101
Nov 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I've got a Maytag model LD9206. It makes a lot of noise when it first starts up, but the noise goes away. The noise is a loud squeak which I believe is probably related to the belt or pullys. How do I...
heatman101
Oct 06, 2010 | Maytag Dryers
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | Maytag Dryers
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Dryers Experts
