Question about Kenmore Vacuums
Cover won't close on sears progressive vac. Stuck open
Lifted cover replace bag and cover seems locked in open position. Don't want to force cover as it feels like it might break
  • 7 Answers
SOURCE: pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Posted on Jan 09, 2008
SOURCE: Kenmore/Sears Progressive 116 How to get housing off to replace cord
There are four screws, two at the front and two at the back under the step bar that rewinds the cord.  It lifts off from the bottom.  Be careful not to snap off the tabs.
Posted on May 15, 2009
  • 38 Answers
SOURCE: My Dyson DC27 Animal is stuck (Locked) in the
Dysons are notorious for this problem. You will have to just force it and clean any obstructions.
Posted on Jul 26, 2009
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
Posted on Mar 09, 2010
  • 2926 Answers
SOURCE: I have a progressive 360
There should be tabs that need to be pressed in, and will allow the filter cover to be removed to access the filter. On some models, the tabs are accessed from the bottom by tilting the unit on its side, or by simply pressing them in from the top, then pull the filter cover up.
Posted on Jan 21, 2011
My vac turns on then right off even after we changed the bag
There may be a safety switch for the bag cover and it may not be engaged properly. Try taking the bag cover off or open it and try closing it again.
Aug 26, 2014 | Dirt Devil Vacuums
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
How do i open my canister vacuum
Open the bag door and grip the bumpers with a set of pliers. The bumpers cover a set of locking keys which will slide all the way forward and out. The back of the vac will then lift off and the top and bottom will open hinging forward like a **** shell. Observe how the front door hinge clips into the lower body before opening teh unit.
If you do this , tag your wires and observe how the pieces interlock. Open the vac with it laying upside down on a piece of carpet.
It will NOT go back togerther unless it is perfectly reassembled , so don't force it.
Post your problem before opening and I will walk you through the reapir
Oct 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kenmoore Intellivac w direct drive suddenly started making internal sound like something was stuck. Hose is clear, and sound is made when hose is detached from main unit. Vacuum sounds find at lower...
Shut off the vac and open container and remove the bag. Try dropping a coin into the hose, then raise up to see if it falls thru to the bag area. If it does check the throat of the vac where the dirt is sucked upward to dump into the bag itself.
Sep 05, 2009 | Kenmore 35912 / 35913 Progressive Upright...
UNABLE TO FIT BELT ON MY ULTIMATE UPRIGHT G BAG VACUUM CLEANER.
You need to disengage the carpet head from the vac itself. Do this by lifting the headlight and rotating the thumb lock underneath. Then release the carpet head by turning the square dial below the light. Once you have lifted the head off the vac you will see from the backside of the head there is a belt hook holding the old belt in a twist.
pop the brush cover off at the bottom of the head but note which end of the brush goes right and left. Slide the new GENUINE belt onto the brush roll and inspect the brush for hair and thread caught at the ends.
Reisnatll the bottom plate in reverse order making sure the brush sits level in the housing.There are leveling blocks at each which are color coded.
Once again rotate the square dial on the front of the housing, in both directions if necessary ,You will feel the dial tension as it hooks your new belt inside the housing and twists it into installation position.
Reinstall the head in reverse order onto the vac.
Aug 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Have a Sears shop vac, mod 113.172. The motor doesn't take in
If the motor turns, you should have suction. Put the hose on the exhaust side of the motor if there is a connection, and try to blow it out. If you can't, try using a garden hose or toilet snake to clear the hose. IF the hose is clear, and the problem continues, check the float in the cage below the motor. It should be down at the bottom of the cage. Also, if you haven't been using a bag or foam cover for the cage, it is possible for leaves to clog the motor.
Mar 15, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
The back filter and cover blow off immed when vacuum turnd on
Has the cover got tabs that is suppose to catch when it's installed? check and see if there are broken plastic ends either on the vac or cover. It should be able to catch to hold it on.
Jan 31, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Vacuums Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
